Flappy blowy engine noise
Old 05-18-11, 04:14 PM
deanbrown
deanbrown's Avatar
Default Flappy blowy engine noise
Greetings.
I've had this valve-train-like noise for a few years now on my 96LS (240K) and it's getting worse and worse - it sounds like something is blowing or flapping when I let off the gas (standing next to the car, that is). I heard about some kind of recirculating exhaust pipe part, but I need more info on this (such as what it's official name is in these forums). Can anyone elaborate on what the part does and how to go about fixing it? Or better still show me a picture of the thing. Sorry if this is a dumb question but I have searched and searched but I still don't get what's going on.
Old 05-18-11, 04:32 PM
LSproject
LSproject's Avatar
I believe its most likely an exhaust leak somewhere. My car is having the same problem and I'm going to take a look at it in a couple of days before I smog the car. Could possibly be the gasket from the block to the headers could have shot out, or from the header to the cat,
Old 05-18-11, 04:47 PM
deanbrown
deanbrown's Avatar
Wouldn't there be an engine code in this case? I had codes when the exhaust rusted through just before the first cat.
Old 05-18-11, 05:12 PM
deanshark
deanshark's Avatar
I think you're thinking of the EGR pipe. It's known to crack. I don't recall if it throws a code, but I don't think it would. There are alot of threads on the subject about how hard (or easy) it is to change. Here are a few. https://www.clublexus.com/forums/sea...archid=6608796
Old 05-18-11, 07:41 PM
sdls
sdls's Avatar
your lower EGR pipe is broken.
Old 05-18-11, 08:56 PM
deanbrown
deanbrown's Avatar
Are there two of these or just one? I only ask because there are two listed on ******* for this engine:
25601 PIPE SUB-ASSY, EGR, NO.1
25601‑50060 1UZFE..UCF20..4FC 1 $122.72
25601J GASKET(FOR EGR PIPE, NO.1)
25634‑50010 1UZFE..UCF20..4FC 1 $5.61
25602 PIPE SUB-ASSY, EGR, NO.2
25602‑50010 1UZFE..UCF20..4FC 1 $116.95
25620 VALVE ASSY, EGR
25620‑50030 1UZFE..UCF20..4FC 1 $454.52
The site is t-o-y-o-d-i-y but for some reason it won't accept this link.
Old 05-19-11, 11:53 AM
steve2006
steve2006's Avatar
It's normally the lower pipe (25601-50060) that breaks at the concertina section,there have been success stories where the break has been welded but considering the pipe is quite difficult to remove and refit replacement may be the best reliable long term solution.
Another point raised was the break could be as a result of worn engine mounts causing excessive flexing of the pipe so it may be worth checking these as well.
deeken
GX - 1st Gen (2004-2009)
12-17-19 09:11 PM
billzblaze
Performance
09-24-11 01:51 PM
SandaraSC4
Performance & Maintenance
05-29-11 12:16 PM
sktn77a
RX - 1st Gen (1999-2003)
16
01-29-09 10:12 AM
BadViper22
23
08-12-07 12:29 PM
Quick Reply: Flappy blowy engine noise
