please help how to change coolant on an 98 ls400
Old 05-10-11, 05:07 PM
GX470GT
GX470GT's Avatar
Default please help how to change coolant on an 98 ls400
please help how to change coolant on an 98 ls400. I wanted to find out how many drain holes are there, and the proper way to do this entire procedure at home.
I already bought toyota coolant 12 quarts of it.
Thank You
Old 05-10-11, 05:14 PM
PureDrifter
BahHumBug
PureDrifter's Avatar
really need to search mate...
Old 05-10-11, 05:47 PM
Vincent123
Vincent123's Avatar
oh god 4 threads in a row
Old 05-10-11, 09:22 PM
RA40
Super Moderator
RA40's Avatar
12 quarts! You'll have plenty for future coolant drains.
If the coolant is well maintained, draining from the radiator is sufficient IMO. It doesn't get it all so if you are OC and want it all out, then you have to do the other drain *****, just adds more time to the drill. I had mine drained from the radiator, new thermostat swapped in, filled then burped in about 45 minutes.
If the radiator drain **** has not been removed for a long interval or the O-ring is heat cycled that little nylon part may leak or break. You may want to have a spare on hand. ~$15 I recollect.
I did the drill one time and the O-ring was dried out so it leaked from there following. No matter how fast you think you are getting the plug back in, it makes a mess. Wear latex or nitrile gloves if coming into contact with coolant. Just a safety precaution in the event your have sensitive skin and or cuts on your hands.
Deaundre
10-05-18 01:17 PM
Elless400
12
05-01-17 09:16 PM
VIPFAMILY
02-24-09 12:07 AM
LS4Lexus
Maintenance
11-11-04 11:50 PM
movies_fun
07-03-01 01:08 AM
Quick Reply: please help how to change coolant on an 98 ls400
