99 Headlight vertical alignment notes
Old 05-07-11, 11:27 PM
deanbrown
deanbrown's Avatar
Default 99 Headlight vertical alignment notes
Greetings.
Here are a few numbers, to add to the several useful posts that actually show you where the two bolts are:
Adjusting one headlight (drivers side in this case)
12 full turns, both bolts (I did 4 lots of 3 full turns each) +
Clockwise ('doing up' the bolt) =
Lowered the beam 3.5" at a distance of 4 feet from the back of the light to the wall in front of the car.
You can draw a level line on the wall to help out.
JohnnyCake
05-05-23 06:09 PM
timgs300
10-14-16 07:41 AM
sojah
10-07-09 06:23 AM
triplecore
09-03-06 06:42 PM
Quick Reply: 99 Headlight vertical alignment notes
