LS400 NRCAs
Old 05-05-11, 10:06 AM
S30ZG
S30ZG's Avatar
Default LS400 NRCAs
My buddy just made me some NCRAs so that I can adjust my front camber significantly more at my current height.
Pictures of them installed on his car.
Pictures of the NCRAs on his UCF10. This is minimum negative camber (-4 according to his math). I'll post some pictures of max as soon as I pic up my set.
The they are made out of 6061-T6 Aluminum and the hardware used is 12.9 grade. They also lower the car 1.25 inches in addition to adding almost another inch of coil-over travel.
Old 05-05-11, 10:41 AM
Vincent123
Vincent123's Avatar
Hmm very interesting. I can get -5 in the rear on stock adjustments w/ my youzealand ss kit installed as well. If I ever need to go more, I might be interested in purchasing a set.
But I'm glad parts like these are finally coming out for the LS guys
Old 05-05-11, 01:07 PM
PureDrifter
BahHumBug
PureDrifter's Avatar
this is more along the lines of the nagisa auto camber adapter from the way it looks.
what i really want is a reasonably priced rear SS kit to relocate the lower shock mount similar to what Youzealand did.
Old 05-05-11, 06:22 PM
jasonm
jasonm's Avatar
Yeah...I'm at -4.5 in the rear on natural camber....Lower your car more and tuck that tire/rim. Then get an alignment and tell us what the camber is at.
Old 05-05-11, 06:43 PM
BLKonBLK98
BLKonBLK98's Avatar
i gotta wonder why this hasn't been done before. seems like it has to have been thought of before which makes me wonder why it's not on the market. can't think of anything at the moment.
Old 07-03-11, 08:37 PM
Rey
Rey's Avatar
I wanted to bump this because its says its for the rear but it looks like its fitted on the front.
Old 07-03-11, 10:54 PM
S30ZG
S30ZG's Avatar
Ya its for the front sorry about that. Editted the first post with a correction.
I maxed my camber out @ -5.5 with these on the front.
Old 07-13-11, 05:04 AM
blkvip
blkvip's Avatar
Any one haw any info on the mock ups or drawings?! friend does milling he was asking me to see if ther are any pics or whatnot so he debt need to start from scratch? any help would b a big help!!!
Old 07-13-11, 05:12 AM
PureDrifter
BahHumBug
actually all you need are the center-center distances of the 2 holes for the lower ball joints, diameters of the bolts, and have him mill a steel insert sleeve.
its more of a production cost thing than a design issue. (for RCAs, NRCAs require more math/geometry to get the right camber change.)
Old 07-13-11, 01:37 PM
blkvip
blkvip's Avatar
^^^intresting thanks guy. ill pass it along.
sgv_bum
01-23-18 10:17 PM
sam430
05-07-16 08:53 AM
Hoac
Suspension and Brakes
09-13-12 05:49 PM
jtsst
10-31-11 08:44 AM
vsynergy
23
12-04-08 07:51 AM
Quick Reply: LS400 NRCAs
