Coolant from Toyota?
Old 05-01-11, 09:35 AM
deanbrown
deanbrown's Avatar
Default Coolant from Toyota?
Greetings!
Can I get the correct antifreeze (for a 96) in a Toy dealership? I only ask because another item (the T4 ATF) is less than half the price it is in the Lexus shop.
Old 05-01-11, 10:26 AM
gemigniani
gemigniani's Avatar
Yes, the '96 takes the red Toyota long life coolant (not the pink super long life). You could theoretically switch to the pink, but getting all the old red coolant out would be a hassle; e.g. some owners can't find the engine block drain plugs or can't figure out how to open the drain plugs. With the red you don't have to mess with those plugs, just drain the radiator, measure the amount drained and refill with the same amount using 50% red antifreeze mixed with 50% distilled water (mix them in a separate container).
Old 05-01-11, 10:32 AM
deanshark
deanshark's Avatar
You can get it at a Toyota dealer seeing how it's a Toyota engine. I'm not sure if the price would be any less though. Although, most "parts" for the Lexus that you can get from Toyota are cheaper. Give it a shot. If you don't have the same type in there make sure you flush all the other type out.
Old 05-01-11, 11:41 AM
deanbrown
deanbrown's Avatar
Last time I bought T-IV ATF, it was $8 / quart at Lexus, and $4 at Toyota.
Old 05-01-11, 12:38 PM
RA40
Super Moderator
RA40's Avatar
You can, I buy most the tranny and coolant from a Toyota dealership.
As far as coolant drain intervals, you have the thermostat to contend with every 30K miles. If even draining off that little bit to swap thermostats, it doesn't take that much to drain it all and be sure. So you are having to do coolant maintenance anyway. I stick with the long life red. One jug is sufficient to do the car about 2 times at a 50-50 mix.
$26 for red and $1 for distilled jug of water. I forget what the pink costs.
Old 05-01-11, 01:03 PM
Hilux22RE
Hilux22RE's Avatar
I Saw on Lexls.com that a the 1990-1994 Used the GM Dex Cool...? Is that correct??
Whats recommended for my 1991??
Old 05-01-11, 01:07 PM
GSteg
GSteg's Avatar
Dexcool is horrible for any car, even for GM's own fleet. That coolant has the tendency to clog the crap out of your cooling system.
Original coolant is actually green, but from maybe mid 90s Toyota came out with the red (long life). Use those instead.
Old 05-01-11, 01:11 PM
Hilux22RE
Hilux22RE's Avatar
So use the Toyota Long Life Red?? I Was doing research before i did the Flush and Fill and i came across this. and i needed to ask before i did anything!
Old 05-06-11, 07:15 PM
Bill Dowd
Bill Dowd's Avatar
I have been using the Toyota red now for 12 years on a 1991 LS400 I change it every 2 years in Dec I drain the block and radiator and just refill it with the red fluid 50/50 with distilled water no flushing I still have the orignal hoses and radiator so far so good
Old 05-06-11, 09:18 PM
deanbrown
deanbrown's Avatar
My '96 has been changed twice since 1998, and at 240K still with original water pump, going string still!
Old 05-08-11, 06:18 PM
feetsies
feetsies's Avatar
The red long life would be the correct coolant for your vehicle year, and you could certainly pick it up at a Toyota dealership. Does the '97 LS400's use Dexron III or Type T-IV?
Old 05-08-11, 06:28 PM
Hilux22RE
Hilux22RE's Avatar
So is there a difference between the Coolant purchased from Lexus and Toyota??
Old 05-08-11, 07:50 PM
feetsies
feetsies's Avatar
No, it is the same.
Old 05-08-11, 08:01 PM
LexFather
Guest
Posts: n/a
Toyota red is pretty much as good as it gets. Amsoil is good stuff too. Some people get a higher performance temp cap and/or thermometer if available...
Old 05-08-11, 11:28 PM
gemigniani
gemigniani's Avatar
No it's not correct. The factory fill on all 1988-2003 Toyota and Lexus vehicles was the Toyota Long Life (red colored) antifreeze.
2004 and on up models use the pink colored Toyota Super Long Life antifreeze
(it's twice as expensive since it comes ready to use instead of as a concentrate that you dilute 50/50 with distilled water).
Quick Reply: Coolant from Toyota?
