worst day ever 96 LS400 problem
Old 04-25-11, 08:30 PM
Abdiel
Abdiel's Avatar
Exclamation worst day ever 96 LS400 problem
Today driving home all of a sudden my 96 LS400 went crazy lost of its power and the engine making some loud weird noise can some one help me please i dont have any other car and im unemployed...
Old 04-25-11, 10:39 PM
Rey
Rey's Avatar
maybe your timing belt snapped...
Old 04-26-11, 05:43 AM
billydpowe
billydpowe's Avatar
no one can help you without facts.......
Old 04-26-11, 06:56 AM
papasmithn
10th Gear
papasmithn's Avatar
When, if ever, was the 90k tuneup done? This is where the timing belt was replaced among other things.
Old 04-26-11, 07:55 AM
91LS400vgb
91LS400vgb's Avatar
don't know about the loud noise, but sudden loss of power could result from a bad ignition coil. Check the resistances (primary and secondary) of each coil and compare to the spec in the shop manual.
Old 04-26-11, 09:00 AM
Abdiel
Abdiel's Avatar
ive did the 90k oil change but havent changed the timing belt... i also spoke to one of the techs at my nearest lexus dealer and he said a coil but wasnt really sure but today im going to exchange the ignition coil... is there a DIY on replacing coils??
Old 04-26-11, 09:09 AM
LiCelsior
Retired
LiCelsior's Avatar
theres two. one in front of the car and one on the side.
Old 04-26-11, 09:13 AM
Abdiel
Abdiel's Avatar
i see the one in the front of the engine but cant find the second one.
Old 04-26-11, 12:35 PM
RA40
Super Moderator
RA40's Avatar
Loud noises are not good. Electronics typically just fail, no noise and car stops running. If you lose one coil, it will sputter and lope along lacking power.
Can you describe the noise before it stopped running?
How many miles on car?
On a re-start, what type of sounds?
My thoughts, seized water pump, broken timing belt. There are a few other possibilities but you'll need to accurately describe the noise and problems.
Old 04-26-11, 01:33 PM
steve2006
steve2006's Avatar
Remove the battery and you will see it mounted on the side of the engine above the AC compressor.
Old 04-26-11, 02:18 PM
Abdiel
Abdiel's Avatar
ok so i found the other coil thanks....
i will record it and post it so you guy can hear it..
Old 04-26-11, 02:19 PM
Abdiel
Abdiel's Avatar
hopefully once i put the coils back it will all work fine..
Old 04-26-11, 03:15 PM
selkirk
selkirk's Avatar
Not to be a wiseguy, but how long ago was 90k for your LS? What's the current mileage?
And when you say the car lost power, you mean it lost all power (and had to be towed because it couldn't move) or it lost some of its power and didn't feel strong, but could still drive?
Old 04-26-11, 03:43 PM
Abdiel
Abdiel's Avatar
Exclamation
it lost most of its power and barely made it up the road..
the car has 150,000 miles on it..
i plug a new coil to the top one and car would not start plug the old one back and plug new one to bottom coil starts fine but when i press the gas the whole car tumbles and shakes sounds a little like a diesel and smells like gas really bad..
Old 04-26-11, 04:48 PM
91LS400vgb
91LS400vgb's Avatar
The smell of gas probably indicates a misfire. You should really perform some diagnostics first before you start swapping parts in and out. Here are the test procedures for a 1991 - it shows how to test for spark and how to test your coils - you should look in a manual for a 1996 in case yours differs.
File Type: pdf
Quick Reply: worst day ever 96 LS400 problem
