need to identify this part of the suspension - Club Lexus Forums
Thread Tools Search this Thread
Old 04-21-11, 06:50 PM   #1
CitySlaka
Default need to identify this part of the suspension
hello , the bushing on this part for my 92 ls400 is bad. i need help identifying it. hope the pic turns out ok its my first time.
CitySlaka is offline   Reply With Quote
Old 04-21-11, 07:18 PM   #2
deanshark
That would be the Strut Rod. http://lexus.sewellparts.com/images/...00/NC0702F.jpg When you reinstall it after changing the bushing the torque spec is 136 ft. lb.
deanshark is offline   Reply With Quote
Old 04-21-11, 07:46 PM   #3
emarknot
actually, that is the rear of the car and that rod is the trailing arm. one of the bushings comes with the trailing arm as an "assembly".......this would be the end connected closest to the car body.
at the other end of the traliing arm, is a bushing i know for sure you can get separately, and this one connects the arm to the bottom of the rear knuckle. it either needs to be pressed in/out or use an air hammer with a chisel bit to get the old one out.
the ones i just replaced were urathane, if you get urathane, make sure you use a dab of bearing grease when you install them as they have a tendency to make noise if you dont.
if you need the knuckle side bushing, i will post the part number tomarrow when i get to work.but im sure someone will beat me to it
emarknot is offline   Reply With Quote
Old 04-21-11, 09:39 PM   #4
deanshark
Actually, I know it's the back, and it is the "strut rod". The front has a "strut bar". Take a look at this # 48780A "strut rod assembly". http://lexus.sewellparts.com/oem-cat...S400-1992.html
The part # for the strut rod bushing is 4872522110. This doesn't show any part # for the bushing on the axle carrier (Knuckle) but I'm sure you can find it somewhere.
Old 04-21-11, 10:48 PM   #5
emarknot
when I was ordering my parts through world pack, it showed the strut rod bushings for the front strut rod. for the rear strut rod, the pic shown was not what I needed, the next part with a pic was listed as the rear trailing arm assembly, minus a bushing at the knuckle side. the knuckle bushing was sold separately. so I ordered the trailing arm knuckle bushing and got what I needed.
so...potatoe...potawtoe...i guess.
Old 04-22-11, 06:34 PM   #6
CitySlaka
Yall stop bickering its the front driver side the pic should make it perfectly clear. Thanks for the responses though.
Old 04-22-11, 06:39 PM   #7
CitySlaka
It does look like the back though.
Old 04-22-11, 07:13 PM   #8
LiCelsior
Liberty VIP
LiCelsior's Avatar
uh the pic u posted is of the rear.
LiCelsior is offline   Reply With Quote
Old 04-22-11, 07:57 PM   #9
deanshark
Right? How can you say that's the front. I didn't know the emergency brake was on the front. It sure looks like the drivers side rear to me. Here we are trying to help you and you don't know which way is front and rear. I might as well say that that part is a muffler bearing clamp washer.
Old 04-23-11, 08:04 PM   #10
CitySlaka
Ok I will order a muffler bearing clamp. What a jerk don't worry about it I will figure it out without you deanshark.
Old 04-23-11, 09:23 PM   #11
deanshark
Quote:
Figure it out without me??? I already told you what it was!! Who's the jerk here? You posted a pic of the back suspension asking what a part was, I told you exactly what your arrow is pointing at, and you're trying to say "its the front driver side the pic should make it perfectly clear." Here we are trying to help you and you're saying we are all wrong.
If you can't tell the front from the back I don't think you should be working on, or even driving, a car.
Old 04-23-11, 11:03 PM   #12
emarknot
werd!...........plus the axle visible in the pic gives it way.
Old 04-24-11, 12:49 AM   #13
PureDrifter
BahHumBug
PureDrifter's Avatar
lol, just lol.
wanna see your 4WD LS400 now.
OP-cut the personal attacks, you screwed up, fix it.
PureDrifter is offline   Reply With Quote
Thread Thread Starter Forum Replies Last Post
Need help in identifying gasket kyk007 LS - 1st and 2nd Gen (1990-2000) 10 04-22-15 03:11 PM
Help identifying OEM bolt part number DeZyn243 LS - 1st and 2nd Gen (1990-2000) 11 06-30-14 03:33 AM
Need help identifying these broken parts! PDXLex ES - 1st to 4th Gen (1990-2006) 6 06-15-14 03:34 PM
Help with Identifying Wheels / Center Cap bkvollmer The Tire Rack's Tires, Wheels & Brakes Forum 4 06-13-14 11:44 AM
Can anyone identify this part? jodyzig RX - 1st Gen (1999-2003) 6 12-12-13 09:46 AM
Tags
2008, air, arm, bolts, box, club, gs400, identify, lexus, ls400, rx350, spec, suspension, torque, trailing
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Copyright © 2000-2016 Internet Brands, Inc. All Rights Reserved
