98 ls400 engine whine! idler pully? alternator?
Old 04-21-11, 02:22 PM
GX470GT
GX470GT's Avatar
Default 98 ls400 engine whine! idler pully? alternator?
98 ls400 engine whines as if there is a supercharger on it. it whines in sync with the rpm's. stops whinning around 2500rpm. idler pully? alternator?
the sound is not very loud, but its there and its annoying!
i can't figure out what pully its coming from. Anyone experience this before?
car has 73k miles
Old 04-21-11, 03:15 PM
RA40
Super Moderator
RA40's Avatar
Unfortunately, this is one of those search and replace scenarios.
Old 04-21-11, 03:44 PM
GX470GT
GX470GT's Avatar
thats what i thought. oh man.... i guess ill start with the idler!
Old 04-22-11, 07:29 AM
etex
etex's Avatar
While the drive belt is off, check the engine-driven fan for back and forth movement. May be the fan bearing bracket.
Old 04-22-11, 08:33 AM
1badlex
1badlex's Avatar
mine is doing a similar thing but mine is more of a squeek
Old 04-22-11, 08:34 AM
sethjon
sethjon's Avatar
car has 73k miles
It could be any pulley. you have to remove the belt and spin them individually. A possibility, albeit probably not, is a water leak that is going on to the belt. That would make a high pitched chirp and go faster as you rev the motor.
sethjon
sethjon's Avatar
car has 73k miles
It could be any pulley. you have to remove the belt and spin them individually. A possibility, albeit probably not, is a water leak that is going on to the belt. That would make a high pitched chirp and go faster as you rev the motor. Also possible to be the water pump. When was it changed last?
Old 04-22-11, 08:42 AM
Silverpaws
Silverpaws's Avatar
I had the same thing happen on a non-Lexus vehicle and I thought it was a number of things including water pump, alternator, pulleys, power steering pump, etc. Turns out that it was the drive belt which had hardened due to heat and age. Was a cheap repair so I would try replacing that first. Those type of noises are difficult to isolate sometimes.
Old 04-23-11, 08:30 AM
waseem3000
waseem3000's Avatar
A whine could be related to your transmission mounting or the rear engine mount (as they call it)... happened with me too... have a look at it first as it could be as simple as that... I thought that it was my engine too but it was definitely the mounting...
txwriter
05-30-18 05:58 PM
MikeyF23
01-16-16 12:38 PM
SynicalVip
06-25-14 11:57 AM
deepbluesk
RX - 1st Gen (1999-2003)
09-07-08 04:17 PM
DroppedGS
01-09-06 06:24 PM
Quick Reply: 98 ls400 engine whine! idler pully? alternator?
