Camry rotors on LS?
Old 03-20-11, 10:57 AM
kuziwk
kuziwk's Avatar
Default Camry rotors on LS?
someone is selling 08 camry rotors for cheap, im just wondering if they will fit my 92LS. He said hey are 11.64 diameter and 114.3/5 bolt pattern.
Old 03-20-11, 11:55 AM
RA40
Super Moderator
RA40's Avatar
If it specs similar to these Brembo replacements, you may be good.
EDIT: OOPS, thinking 2-LS not 1-LS.
296 mm diameter; 32 mm thickness; 30 mm minimum thickness; 50.5 mm overall height
Old 03-20-11, 11:59 AM
LiCelsior
Retired
LiCelsior's Avatar
dont do it.
Old 03-20-11, 04:11 PM
PureDrifter
BahHumBug
PureDrifter's Avatar
lol are you serious?
there is a 95% chance it wont fit, but to confirm that you'll have to either go buy/borrow them or get a lot better measurements than what you have now....
Old 03-20-11, 04:19 PM
nine3es
nine3es's Avatar
even if they do/did fit, the camry is a much lighter car and would not provide as much stopping power as your oem calipers imo.
check on the 2gen LS calipers, i think they are supposed to fit and they are 4 piston calipers.
Old 03-20-11, 05:04 PM
sethjon
sethjon's Avatar
I doubt if they're big enough if they would fit on. Its a safety thing, why screw around. Rotors are not expensive.
Old 03-20-11, 06:21 PM
Kansas
Kansas's Avatar
The recent Camry V6 has an advertised curb weight within about 275 pounds of a 92 LS400 -- pretty close and less than the weight of each of three of my four brother-in-laws. If the Camry's rotor dimensions are the same as that of a 92 LS400, then why not use them?
Mid430blue
08-23-10 12:13 AM
gman1227
09-13-08 06:50 PM
Spitfire86
Suspension and Brakes
11-28-07 09:56 AM
cpone
09-02-06 05:25 PM
James1830
SC- 1st Gen (1992-2000)
09-14-05 08:10 AM
Quick Reply: Camry rotors on LS?
