it this natural? (fan comes on when turn key to the on position and stays on)
Old 03-13-11, 05:44 PM
Dtwillis5
Dtwillis5's Avatar
Default it this natural? (fan comes on when turn key to the on position and stays on)
My fan come on when i put the key in and turn it to the on position and stay on .
Old 03-14-11, 07:10 AM
acidfire52
acidfire52's Avatar
Which fan? Radiator or Interior?
Old 03-14-11, 07:42 AM
deanshark
deanshark's Avatar
Either one is not normal. The radiator fan comes on at a certain temperature unless ya have a direct switch hooked up and the interior fan, I think, is just barely turning until you turn on the HVAC.
Old 03-14-11, 01:06 PM
Dtwillis5
Dtwillis5's Avatar
The 2 black fans and the air be off.
Old 03-14-11, 07:14 PM
tomtheslac
tomtheslac's Avatar
Heater fan relay is probably bypassed or stuck. Pull the fuse cover under the hood by the battery and check. The layout should be under the cover if you don't know which one it is...
Old 03-15-11, 07:13 PM
steveski
steveski's Avatar
Also check the sensor unit (if it is plugged into radiator). I believe it is on driver's side behind radiator. Mine was unplugged and the fan was always running - plugged the sensor in and it stopped.
Kretek234
12-01-20 03:58 PM
Kurtmaramb
06-02-18 03:33 PM
Murphydurf
GS - 1st Gen (1993-1997)
08-15-13 05:52 PM
MiamiLs400
02-06-11 09:20 PM
W92ls400
12-10-07 04:31 PM
Quick Reply: it this natural? (fan comes on when turn key to the on position and stays on)
