How to remove rear seat on 2000 Ls400
I have a 2000 Ls400
I have already searched everywhere and I couldnt get the clear answer on how to remove my rear seat.
Does anyone know how to do this?
Do not say pull tabs or anything because my car does not have that!
and do not give me a link to lexls.com cause they only have the 90-94 version.
Found this on a different site. (Lexus Owners Club) It's for a 96, Idk if it's the same for a 2000 seeing how I have a 93.
There are four retaining clip,two each side of the center arch, one in the center and the other around the side by the door of the seat area.
To remove seat just put your hand under the seat an pull strate up, starting from the door sides then the center of each seat area.
Lift the seat up from the front. and slide the back down and forward to alow the retaining guides to slide from the back rest.
BahHumBug
I have a 2000 Ls400
the lexls link is right, with the only difference being you dont pull up on tabs so much as you just pull up on the bottom of the seat...
if you remove the seat back, don't forget to remove ALL screws. There are a couple in the center behind the arm rest. i made this mistake and my rear seat is warped. luckily it's not enough for anyone to notice!
