which sensor is this?
Old 03-01-11, 08:40 PM
wcoastls
wcoastls's Avatar
Default which sensor is this?
on attached pic, red arrow points to ect sensor, but my question is what sensor is the one above/right (shiny brass) to ect sensor? is it the oil pressure sensor? please advise. grazie.
Old 03-01-11, 09:02 PM
miles56
miles56's Avatar
My friend this is a temperture control senor !! 100% sure--I need to replace the one on my 1992 lexus with 216,100 miles. Hope that I was helpfull ,So many people on this forum has help me.A many thanks
Old 03-02-11, 12:20 PM
wcoastls
wcoastls's Avatar
i dont know if u read the posting, but im aware the red arrow pointed sensor is ect. i was referring to one above to right. or i could be mistaken and there are 2 etc sensors??
Old 03-02-11, 06:40 PM
deanshark
deanshark's Avatar
Actually there are 3 coolant sensors. The one you are asking about is the coolant sensor that works the gauge on the dash, it has one wire in the plug.
Old 03-02-11, 07:33 PM
wcoastls
wcoastls's Avatar
3 coolant sensors?? wow, i feel so behind on this diy situation... the gauge one seems to work fine. thanks miles & dean for the 411.
Old 06-08-11, 04:05 PM
Hilux22RE
Hilux22RE's Avatar
Sorry to bump this one but there is a Sensor a little to the Right of the ECT. i understand there are 3 Sensors but how do i ask for the one Next to it? Its a Gray Connector.. are they both the same Part #?
It would be cool if they were the same but i would be cool if i got the name of it??
Old 06-08-11, 08:02 PM
deanbrown
deanbrown's Avatar
Maybe next time you could put the big red arrow onto the right sensor?
Old 06-08-11, 08:43 PM
Hilux22RE
Hilux22RE's Avatar
You cant see the sensor Behind the Coil... and the pic isnt mine... i need to snap a pic of it
Old 06-09-11, 09:09 AM
deanshark
deanshark's Avatar
The only sensors in that area, that I remember, are the 2 that are shown in the pic. I even looked through my whole manual b/c this was bugging me. (nothing better to do) The one with the gray connector is the one the original poster asked about, which is already disconnected. But anyway, it's called the "ECT gauge sender", that one controls the temp gauge on the dash. And just for further reference the sensor on the bottom of the radiator is called the "ECT switch", that one controls the fans. I hope that clears it up for anyone in the future about the "3" ECT's. They should have different names so people don't confuse them but they all deal with the "Engine Coolant Temperature".
ECT sensor
ECT gauge sender
ECT switch
Old 06-09-11, 11:20 AM
Hilux22RE
Hilux22RE's Avatar
I might take a pic Later today.. but there is the Brass Single Cable Sensor Above the Green Connector Like in the pic, The ECT that is the Green Connector, and Just to the Right of that one is a Gray Connector with another sensor.. i Searched on Alldata and Came up with the "Start Injector Time Switch"
I Have no clue if this is correct or what..
Old 06-09-11, 11:58 AM
LEXTEK1
LEXTEK1's Avatar
Why do you want to change this sensor?
Old 06-09-11, 12:04 PM
Hilux22RE
Hilux22RE's Avatar
i dont want to i was just Curious as to what it is and does.
Old 06-09-11, 03:45 PM
deanshark
deanshark's Avatar
I guess there's a sensor I didn't remember seeing there. This is copied from an article at Lextreme;
"The V8 is fitted with a cold start injector that is operated by a thermostatic start injector time switch when the coolant temperature is less than 22 degrees Celsius."
Old 06-09-11, 04:40 PM
Hilux22RE
Hilux22RE's Avatar
That is interesting. Good to know!
Thank you very much Deanshark!
S160dre
08-11-16 06:36 AM
ViPeRs103
07-04-15 09:47 AM
SMUChris
12-17-12 03:50 AM
Quick Reply: which sensor is this?
