1990 LS400 Brake upgrade
Old 02-16-11, 07:59 AM
gribley
gribley's Avatar
Default 1990 LS400 Brake upgrade
I am going to upgrade the front brakes to 4 pots.
I have seen Supra kits advertised for £600.
I have priced up 95-2000 LS 400 kit at about £450 + shims + pins. but then I believe a set of lower ball joints is needed, then it will need tracking so the price difference will be negligible.
So which is the best value for money?
Which need least wheel clearance for the calipers?
I have 10 spoke GS300 wheels on and with the std discs I have 66mm clearance
Will 95-2000 LS 400 rear discs and calipers fit the 90 ls 400?
Old 02-16-11, 04:22 PM
PureDrifter
BahHumBug
PureDrifter's Avatar
rears should fit but are the same size so arent an upgrade.
UCF20 fronts should be cheaper than that, in the US the going rate is ~$300-350USD for a set incl. rotors used.
Old 02-17-11, 02:29 PM
S13REMI
S13REMI's Avatar
i would go with the ucf20 4pots, i just finish mine the day before my car stopped starting :/ but in the time i was driving with them i did a few hard stops noticed a difference. i would deffinetly recommend the ucf20 brakes!
Old 02-17-11, 06:31 PM
BLKonBLK98
BLKonBLK98's Avatar
ucf20 rears are an upgrade on the 90-92, on 93-94 they are the same.
it's a shame you're not close op, i have a complete and customized 90-92 setup with low miles way cheaper.
Old 02-17-11, 06:46 PM
S13REMI
S13REMI's Avatar
are the rears bolt on?
Old 02-17-11, 08:24 PM
hobojoe
hobojoe's Avatar
I would be interested, at least in the rears to start if they clear the standard 91 wheels? Since I only run the volks in the late springs to late fall.
Old 02-23-11, 07:34 AM
gribley
gribley's Avatar
As I said the cost difference is negligible. If I buy refurbished calipers, new discs, new bottom ball joints, new fitting kit and new shims it will cost be about £550. I can get a supra kit for £600.
I may be tempted to buy the supra kit if its less messing. but i need to know if the calipers will fit under my wheels. How deep is the supra caliper from the disc surface to the face thats says "supra" on i
Old 02-23-11, 03:36 PM
PureDrifter
BahHumBug
the LS caliper is wider but much lighter (completely alum, the super caliper is half steel)
OG Dada
Suspension and Brakes
188
02-04-16 09:56 AM
BLKG3
12-20-09 11:30 PM
v276482
07-11-09 11:20 AM
TheCoupe
55
05-17-09 01:09 AM
jgscott
04-26-05 08:15 PM
Quick Reply: 1990 LS400 Brake upgrade
