Battery eating while car is off?
Old 02-02-11, 01:30 PM
TLsc300
TLsc300's Avatar
Default Battery eating while car is off?
any idea of this?
Old 02-02-11, 02:01 PM
python
python's Avatar
talk about a vague post...
Old 02-02-11, 03:19 PM
LiCelsior
Retired
LiCelsior's Avatar
You need more info, install anything recently? Any past battery problems?
But to answer your post, You have a parasitic drain, have fun tracing it. /thread.
Old 02-02-11, 04:46 PM
randal
randal's Avatar
How do you know the battery is eating? Is there a munching sound coming from underneath the hood?
Old 02-02-11, 06:28 PM
RA40
Super Moderator
RA40's Avatar
Personally I don't find the oxidation mixed with road grime to be very appetizing. Plastic is yuck. This is better eating:
Hahaha...
Put the car in a dark garage and see if any "off" lights are faintly glowing. The turn signal/light switch stalk on one of my past cars had become worn so the light switch was just loose enough to make contact. Not enough to fully light the headlights but enough to complete the circuit.
Otherwise, any number of your add-on accessories will need to have the wiring checked.
Old 02-02-11, 06:30 PM
BLKonBLK98
BLKonBLK98's Avatar
i'm assuming it stops eating if the car is on (?). sounds like some sort of obsessive compulsive disorder.
Old 02-02-11, 06:37 PM
Imperium11
Imperium11's Avatar
lock your battery away where your car cant find it
Old 02-02-11, 07:50 PM
LiCelsior
Retired
LiCelsior's Avatar
mmmm bacon
Old 02-02-11, 09:33 PM
AzHotLS
AzHotLS's Avatar
Well, considering this is your car:
https://www.clublexus.com/forums/ls4...-my-ls400.html
it could be many things.
RA, I'll take a few slices.
Old 02-03-11, 12:24 AM
Imperium11
Imperium11's Avatar
lol its probably snow shorting a plug or something in around the crevasse that exists there
Old 02-03-11, 06:53 AM
python
python's Avatar
yikes...
i tried bbq'ing some beans the other day but they kept falling through the grill
Old 02-03-11, 07:14 AM
LiCelsior
Retired
LiCelsior's Avatar
^tin foil man!
Old 02-03-11, 07:19 AM
williamb82
williamb82's Avatar
since the car has a factory alarm, that will always put a draw on the battery while the car is off and it is armed. also the radio and ecu have power lines that are constant for memory purposes etc...., then theres the posibility you have something thats being left on for whatever reason.
Old 02-03-11, 08:14 AM
deanshark
deanshark's Avatar
Did you ever get the front of the car fixed? It could be when it was in the accident that some wires got cut or stripped and their getting grounded out or something. Check every wire in that area. I hate electrical problems but it usually turns out to be something stupid, but simple. Mysterious draws are a PITA, good luck.
Old 02-03-11, 12:34 PM
SRV1
SRV1's Avatar
The battery got high and it now has the munchies.
Quick Reply: Battery eating while car is off?
