Strutmaster Convo vs. Megan Coilovers
Old 01-09-11, 03:03 AM
NTRUDA
NTRUDA's Avatar
Default Strutmaster Convo vs. Megan Coilovers
This is my first thread as I have been on the sight for a short time. I have a 91 ls400 with 235k miles on it. It came fully load with the air suspension system. The front end is totally on the ground and I'm looking to get rid of the air suspension setup. I have researched the Strutmasters but just recently came across the Megan Coilovers...My question is which is a better setup based on how well a lexus is know for it's ride feel? I am leaning toward the Strutmasters but I will greatly welcome any input about the Megan's if they are a better choice? Thanks for all of your answers and I am glad that I found and joined the club....
Old 01-09-11, 06:34 AM
LiCelsior
Retired
LiCelsior's Avatar
strutmasters would be oem ride. megan coilovers will be a more sporty ride, with height/dampening adjustment.
Old 01-09-11, 07:24 AM
radiokilla
radiokilla's Avatar
I have megan racing coilovers on my 92 UCF10. I set the dampening to 0 on all four corners and it is a very livable ride on freeways. Depending on your age and driving style it may not suit you on rough roads which combined with a stiff suspension can get quite bumpy. However, you can set the dampening anywhere from 0-32, 32 being the softest and probably the closest to oem spec. The spring rates are adjustable on the megans as well but I don't recommend that you change the factory spring rates. Good luck and welcome to ClubLexus!
Old 01-10-11, 01:53 PM
NTRUDA
NTRUDA's Avatar
I want a little bit of both...so I guess I wll get the megan-but I might upgrade to the megan lp's...but I'm going to do a little bit more research before I make my purchase...I also want to go with a bigger tire size so I might just upgrade the sway bars, bushings, replace/repair control arms, etc....I not looking to do alot of overkill but I'm just looking to up/replace neccessary parts and repair since I've had the car since 91...thanks for the your input...
Old 01-10-11, 01:59 PM
Schnitz
Schnitz's Avatar
Take a look at BC Racing coilovers as well. PM BLKonBLK98. He can answer all your questions.
Old 01-10-11, 02:04 PM
LiCelsior
Retired
LiCelsior's Avatar
bc coilovers would work but it might put the car too low even at max height.
Old 01-10-11, 02:23 PM
NTRUDA
NTRUDA's Avatar
Good looking out...I'll look at those and contact BLKonBLK98 if I got any questions.
Old 01-12-11, 03:05 PM
NTRUDA
NTRUDA's Avatar
Ok...I'm going 2 go with Megan Coilover LP's..they seem 2 give me the type of upgrade that I'm looking for...Hopefully I can find them for a good price...thanks for the info that you all provided....
Old 01-13-11, 11:33 AM
CircuitMS
CircuitMS's Avatar
The Megans or BC's would both be a good upgrade as a full package.
PM us if you'd like some pricing or help
cheesey1x
26
05-01-13 11:19 AM
gs4bkny
12-08-12 10:11 AM
96732IS350
Suspension and Brakes
08-05-11 05:55 AM
AAHawaii07
IS - 1st Gen (2001-2005)
01-14-11 08:52 AM
Quick Reply: Strutmaster Convo vs. Megan Coilovers
