Rod knock!?
Rod knock!?
So i noticed a slight ticking noise on the driver side of my motor, could it be rod knock? Its a 92 ls400, if so should i just get a different motor or rebuild? Which would be cheaper/easier
Does the "ticking" get more pronounced (louder) as the engine warms up?
A spun rod bearing is usually VERY noticeable. Like, 'shut it down now before she blows' noticeable.
The ticking is much more likely to be excessive valve clearance on the left side cam.
What weight oil are you using these days?
The engine was warm when i heard the ticking, as i rev it just escalates with the rev it doesnt seem like it gets louder, what would make the excessive valve clearence?
Is this ticking sound why you are thinking of swapping the engine for a 95?
Yea, i found one fairly cheap so i was gonna change it out, idk what to do haha. So should the ticking escalate with the rev if its vavle clearence?
AND it appears that you do NOT need a new engine. Granted 400k miles on your engine means it is probably a little "tired". On the other hand, if the engine runs reasonably well, wouldn't you want to see what mileage you could get out of her? 500k is a milestone and right around the corner. The reason I asked about oil weight is that you *may* want to consider a higher viscosity oil given the number of miles on the engine. That alone could quiet it a bit.
Take it to a shop and let them listen to it. It is kinda hard for us on a forum to know for sure but don't throw in the towel on this engine until you have determined the root cause. Problems are more often than not, rather simple but we tend to think of the worst possible scenarios. Chances are this is not a bad rod bearing or anything very serious.
If, on the other hand, you are just itching to change out that motor, go ahead and let us know how it turns out. Take lots of pics and post a tutorial. Best wishes if you decide to go that route.
