'92 LS excessive gas use-How to check codes?
Old 11-05-10, 12:23 PM
jerryparks
jerryparks's Avatar
Default '92 LS excessive gas use-How to check codes?
How do I go about checking codes on my '92LS? How do I access them
and where are they displayed? Thanks
Old 11-05-10, 01:53 PM
91LS400vgb
91LS400vgb's Avatar
See this:
http://www.lexls.com/tutorials/intro/codereading.html
Old 11-05-10, 02:58 PM
jerryparks
jerryparks's Avatar
Default accessing codes from tutorial
I dont seem to be getting any response when following the instructions
on the tutorial site. In viewing the videos, it appears the trans should be in Park, not neutral like the instructions say. Which is it? I'm trying to ascertain why my car is using so much gas. ( 15MPG)
Any ideas would be appreciated. Thanks
Old 11-05-10, 07:51 PM
91LS400vgb
91LS400vgb's Avatar
Not sure. How many miles are on your car, btw? Have you ever changed the oxygen sensors? My fuel economy increased substantially after I changed them at 92k. Of course, that is just one of many variables that affect gas mileage.
Old 11-05-10, 11:26 PM
Bali26
Bali26's Avatar
Check thermostat, sparkplugs, sp wires, dist and rotor, o2 sensors, coolant temp sensor.
I get 16mpg city and that's normal per EPA
Old 11-06-10, 02:04 PM
jerryparks
jerryparks's Avatar
I have already replaced the coolant temp sensor. I'm now getting ready to do the
O2 sensors. Just finished researching the 02 posts on this site. Now trying to decide
whether to go with OEM or generic ones. I'm glad there is a lot of info on this site
on this issue. BTW: Most of my LS driving up to this point has been local in town driving.My Nissan Z's get at least 20+ in town driving- so I am expecting to get some improvement after I eliminate all the bugs. Thanks for all your help!
I am also not getting any warning codes either.
Old 11-07-10, 07:09 AM
deanshark
deanshark's Avatar
I doubt you would get any codes just for bad MPG which,15, isn't bad to begin with. It's all about your driving style. Remember, you are driving a V8. The best way to get good mileage is to have a lite right foot, something none of us have. With my heavy foot I get 14 MPG and I think that's pretty good for a V8. Changing the o2 sensors will help a little bit but there is soooo many variables that work together. Just think, you can dump thousands into it just to get a couple more MPGs.
gs350lex
04-13-19 07:38 AM
warminwisc
IS - 1st Gen (2001-2005)
08-16-15 08:10 PM
sflexusman
10-14-11 09:34 AM
swiftscsi
ES - 5th Gen (2007-2012)
13
08-27-10 05:55 PM
Quick Reply: '92 LS excessive gas use-How to check codes?
