What type of oil do you use? (The Mother thread)
Old 06-26-10, 01:56 PM
  #211
malikqais
malikqais's Avatar
Default What Type of Engine Oil LS400 2000 model
Hi Guys,
Ok I know we have so many threads discussing the oil. But all those threads make us confuse. Now here in UAE, I came across an oil specially designed for lexus but it's API is SM ,not SJ as recommended for our car. I am using it now but I am worried maybe the engine will have problem by using SM oil which is only for engines developed after 2005 and mine is 2000.
So I think you might have any idea about this synthetic or non synthetic which makes Engine more quiter because I think synthetics make engine noisier than non synthetic. Please post replies
Thanks
[IMG]c:\oil.jpg[/IMG]
Attached Thumbnails What type of oil do you use? (The Mother thread)-oil.jpg
Old 06-26-10, 07:53 PM
  #212
kuziwk
kuziwk's Avatar
rule of thumb dont EVER switch to synthetic on a high mileage engine, only use synthetic if that was what was originally used. I use castrol gtx high mileage semi-synthetic , which i believe is the same as synthetic provided i change it at the recommended intervals.
Old 06-26-10, 07:58 PM
  #213
PureDrifter
BahHumBug
PureDrifter's Avatar
there's nothing wrong with switching to synthetic, the weight matters more.
i've switched 5-6 cars (all at 80k miles or higher) to full synthetics (both petro and ester based) without issues.
Old 06-26-10, 09:24 PM
  #214
johnnyg66
johnnyg66's Avatar
At 200k miles i am staying with non synthetic oil. Don't want any surprise leaks. Use a good filter like K&N. Just change oil more often or at least every 3k or 6mos.
Old 06-26-10, 10:03 PM
  #215
kuziwk
kuziwk's Avatar
same here man 200 000 miles on my 92 ls400, 80 000 miles is not even high mileage especially for a toyota. i switched my neon with 100 000 miles to synthetic and no problems, runs great.
btw lexus oil is a waste of money, if you want synthetic just go get some castrol.
Old 01-01-11, 10:46 AM
  #216
somnoboy
somnoboy's Avatar
Default First Gen - Castrol Edge oil?
Don't mean to beat a dead horse here, but I want to ask this again because I didn't get any responses to this a while back:
Is anyone using Castrol Edge oil in the First Gen?
I'm due for an oil change in the next week or two. I've got a -YZZD3 filter ready, and can select my oil. The difference in price between the Mobil 1 and the Castrol Edge is fifty cents per quart.
I'm using Mobil 1 5W-30 right now.
Old 01-01-11, 11:12 AM
  #217
RA40
Super Moderator
RA40's Avatar
Do a base analysis then one after it has been in the car for the interval you drain at. Then you will have a direct answer for your application. Otherwise, it is to broad a question to ask since each car will give different results. IMO, don't bother, stick with the M1.
I am curious about the Wal Mart Super Syn.
Old 01-01-11, 03:58 PM
  #218
somnoboy
somnoboy's Avatar
Part of me is inclined to stick with the M1, but I am curious about Castrol's claim in its TV ad that it is 8X better than M1. If true, I'd want to go with the Edge. I just thought someone else here would have tried it on their First Gen already. Just thought I'd ask.
Old 01-02-11, 08:04 AM
  #219
trukn1
NELOC Mod
trukn1's Avatar
I use it now in my 92. Really not noticing any BIG difference over the M1.
Old 01-02-11, 08:34 AM
  #220
somnoboy
somnoboy's Avatar
Thanks trukn. I might give it a try as well in my 92.
By the way, when are you going to post a tutorial on those turn-signal side mirrors? I WANT those on mine... You have a very beautiful machine.
Old 01-02-11, 11:13 AM
  #221
iamviolet
iamviolet's Avatar
been using edge since last year... buy the 5 gallon at Walmart.
Old 01-02-11, 12:11 PM
  #222
somnoboy
somnoboy's Avatar
Thanks for the feedback violet. That's another vote for the Edge.
Anyone else?
Old 01-02-11, 05:53 PM
  #223
PureDrifter
BahHumBug
been using edge since last year... buy the 5 LITER at Walmart.
thats useful when the engine needs ~5.7L of oil lol (at least my '99 does)
Old 04-24-11, 04:52 PM
  #224
emarknot
emarknot's Avatar
Default a look inside...300k mi and synthetic oil
while i had the oil pan off, i thought i would snap a couple shots. not a hint of sludge anywhere.
Old 04-24-11, 05:23 PM
  #225
PureDrifter
BahHumBug
good to see some gold
Quick Reply: What type of oil do you use? (The Mother thread)
