Low Wiper Fluid? NOT
Old 09-12-10, 04:16 PM
cgreenberg
cgreenberg's Avatar
Default Low Wiper Fluid? NOT
My "low wiper fluid" light came on when I hit a pothole last week. I have plenty of wiper fluid. In fact, it's full. I fished around with a coat hanger trying to feel for the float with no avail. Also disco'd the battery. That didn't work either.
Any ideas on how to get rid of this annoying alarm? I'd even live without it completely
Th you!
Chip
98 ls400. Approaching 85k miles, my first full oil change since purchase.
Old 09-12-10, 05:02 PM
Kansas
Kansas's Avatar
You just bought the car and are ready to let repairs slide?
You might start by checking the connection to the washer fluid level switch since you said it stopped working when you hit a pot hole. Access to it is through the driver's side wheel wheel after removing the wheel well liner enough to get to it -- diagram attached.
Attached Thumbnails Low Wiper Fluid? NOT-1998-ls400-windshield-washer-level-switch.jpg
Old 09-12-10, 10:59 PM
PureDrifter
BahHumBug
PureDrifter's Avatar
the float is known to die after ~10 years, just doesnt really float anymore. if you tried the poke and dislodge method to no avail and don't really care for the alert you could do what i did.
i just disconnected the sending unit and tucked the wire out of harms way. no more alert the sensor can be replaced, but you would i believe need to remove teh whole reservoir and honestly, i dont use my wiper fluid enough anyway.
Old 09-13-10, 04:47 AM
cgreenberg
cgreenberg's Avatar
Thanks folks.
Kansas, it's not that I'm skipping maintenance. In fact I'm pretty picky about it. I manually check my fluids every month. Really don't need it. In fact, never had a car with that feature. My $60k Audi s4 didn't have it.
Thanks for the help
Chip
Old 07-25-17, 11:41 AM
lexus94ls
lexus94ls's Avatar
Default 1994 LS400 same problem but...
My '94 LS400 has it's light on with full washer fluid.. I do see something odd in my reservoir though - there is a 1/2" thick and a little over 1" wide strip of white Styrofoam that comes all the way to the top of the filler neck.. I checked the diagram attached in the thread and this doesn't appear to be a part? Is this someone's odd attempt at fixing something with the sensor, and can it be removed? I'd like to know why this Styrofoam piece is in there, maybe when the washer fluid tank was shipped - a replacement part? I'll get a photo when I can.
Old 07-25-17, 02:35 PM
creilly
creilly's Avatar
I think I know what you're talking about, mine has one too. I think the top of that foam piece is supposed to mark the fluid level on the lines. So when the top of the foam is at the top line of the reservoir, that's when you know it's full.
Old 07-25-17, 09:02 PM
valex
valex's Avatar
I did the same thing on my 99LS
gc9538
04-30-18 01:36 PM
GmanSC
03-27-17 04:07 PM
MikeyK02
04-26-10 09:51 AM
dkingphd
01-06-08 04:01 PM
Macgyver
11-18-06 08:15 AM
Quick Reply: Low Wiper Fluid? NOT
