trac light 19
trac light 19
so i bled the system with two small bottles of brake fluid. It was good for a day, but than the next morning when i was idling the car the light came on again. Now the trac light comes on not from pressing the brakes 10 times, but when i hit a certain speed around 50 km/ph. Flushed a litre of brake fluid down today, same thing. Diagnostic's said the same code again, code 19. does anyone know whats going on here?
19 - TRAC motor ON and OFF operation is higher than a predetermined number of times (accumulator pressure leakage)
Do you have fluid leaking, enough to where it is losing pressure? Vacuum leak?
shajbot
07-16-11 06:30 PM
sc400ky
Performance & Maintenance
02-10-08 09:45 PM
