Traction/ABS problem
Old 08-27-10, 03:00 PM
bornpeace
bornpeace's Avatar
Default Traction/ABS problem
Newbie here, i need some help. I changed strut, bushing, control arm this weekend because of alignment problem. after i was done i drove for like a mile til i came to stop sign. When i press pedal to stop, i get a kick back push and the car stop(i assume is ABS). Then when i give it some gas, trac light blink and the car would not move for like 2 seconds. After the car move ABS light will come on for sometime and goes off. What can i do to solve this problem? i didnt have this problem before change suspension components.
Old 08-27-10, 05:33 PM
RA40
Super Moderator
RA40's Avatar
Pinched brake line?
Old 08-27-10, 05:37 PM
JimsGX
JimsGX's Avatar
Let us know what year your LS is... It sounds like you may have disrupted one of the anti-lock brake / speed sensors that bolt into the rear of the front hubs... I'd start by checking those out.
Old 08-27-10, 08:54 PM
RA40
Super Moderator
RA40's Avatar
+1 that sounds more likely.
Old 08-27-10, 09:20 PM
bornpeace
bornpeace's Avatar
i have a 99, i will check on the sensor after work tomorrow together with the brake line then i will come back with the answer. Thanks
Old 08-28-10, 04:21 PM
bornpeace
bornpeace's Avatar
Okay, so i went back and check, i think i pull the sensor cable of driver side too tight. i passed the cable over the top instead of under the knuckle. My question is how can i eliminate the problem? if i have to get a new sensor, does it come with the long cable (coz i dont see anywhere to detach sensor and cable)?
Old 08-29-10, 04:46 AM
JimsGX
JimsGX's Avatar
The sensor & cable is a one piece long cable on the earlier cars. I think it's the same on the 99 LS.
Old 08-29-10, 04:52 PM
bornpeace
bornpeace's Avatar
Thanks jimsGX and others
LS460ROCKS
08-04-17 08:26 AM
marok
01-22-15 10:15 AM
silos5
24
11-23-10 10:09 PM
DUKE34
RX - 1st Gen (1999-2003)
11-18-09 09:08 AM
dannyypk
Maintenance
10-31-04 09:14 PM
Quick Reply: Traction/ABS problem
