97 ls400 coach edition ...MY HARNESS CauGHT ON FIRE !!! is this a common thing ?
Old 07-14-10, 08:44 AM
inshallah
inshallah's Avatar
Default 97 ls400 coach edition ...MY HARNESS CauGHT ON FIRE !!! is this a common thing ?
okay i have a 97 ls400 coach car was parked upw ith key off and the alarm came on dash lights started blinking wipers going nuts i saw the smoke coming from under the passanger glove box i took it apart its a brown wire the wipers wont shut off no matter what i do ...any help ? email me rxr8ted@aol.com
Old 07-14-10, 11:24 AM
stanleyCa
stanleyCa's Avatar
damn thats pretty scary bro
Old 07-14-10, 11:30 AM
PK_Celsior
PK_Celsior's Avatar
i highly doubt its a common thing. the wire harness probably just gave way after time. but my 95 ls400 has 220k miles and everything still runs fine!!!! but i can see my wire harness breaking apart slowly
Old 07-14-10, 12:10 PM
Thermactor
Thermactor's Avatar
The only less-than-perfect part of my '96's harness is the engine coolant temp sensor connector tab. So, you should be able to find a replacement harness in good nick if you are willing to look!
Old 07-14-10, 02:15 PM
inshallah
inshallah's Avatar
okay guys thank you so much for taking intrest so heres what happend ...my car is super slammed my driver side wheel was rubbing and it made the wire harness on top scrape into eachother till it got a fire it burned from the wheel going inside going straight to the passanger side ......i need a harness 8-( i dont wana sell but i might be forced to but i was wondering is allt he first gen harness the same if so i can fix
Old 07-14-10, 02:17 PM
LiCelsior
Retired
LiCelsior's Avatar
just re wire it.
Old 07-14-10, 02:21 PM
inshallah
inshallah's Avatar
probally have to but i have another harness well whole car for that matter a 94 will it work ?
Uploaded with ImageShack.us
Old 07-14-10, 02:22 PM
PK_Celsior
PK_Celsior's Avatar
i believe the wire harness is different from the 1990 - 1994 and 1995 - 1997!!!!!!! getting a new wire harness would be the best route to go, cause your not sure if there still shortages in the wire itself to cause more of a problem later down the road
Old 07-14-10, 02:24 PM
inshallah
inshallah's Avatar
yea your right any idea were i can get one ?
Old 07-14-10, 02:29 PM
PK_Celsior
PK_Celsior's Avatar
you can probably try to a local junkyard call around and see what they are asking for them or call the stealership :x (i just recommend the stealership because if your gona replace it might as well get a new one) there is also swell lexus our vender that could help you out or carson toyota. so you have a few options
o yea super clean ls400 !!!!! i have the same color just in 95 but mine has mad battle scars :x
Old 07-14-10, 02:33 PM
inshallah
inshallah's Avatar
thanks ..my one is actually pretty clean original paint it was int he family from brand new just got it off my uncle this year it was bone stock i put wheels bags system ect small stuff and then THIS HAPPEND!!!! lol uhmm any websites were i can just order one ? but is the coach edition the same ?
Old 07-14-10, 02:46 PM
LiCelsior
Retired
LiCelsior's Avatar
try www.rockauto.com
Old 07-14-10, 02:53 PM
PK_Celsior
PK_Celsior's Avatar
theres no big difference between the original 95 - 97 ls400 compared to the 95 - 97 ls400 coach. its just that you got better leather interior and the car also came with a coach bag.
http://www.trademotion.com/partlocat...?siteid=214915
carson toyota
http://is.sewellparts.com/
swell lexus
Old 07-14-10, 04:24 PM
PureDrifter
BahHumBug
PureDrifter's Avatar
car-part.com
Old 07-15-10, 01:14 AM
Myblacksc
Myblacksc's Avatar
I had that problem (wheel rubbing harness) on my SC. I noticed it early on. Blinkers won't turn off, etc. so I re wrapped the exposed wire with electrical tape (pretty much all of them), wrapped everything together with tape and relocated up more so it wont rub.
Quick Reply: 97 ls400 coach edition ...MY HARNESS CauGHT ON FIRE !!! is this a common thing ?
