Weird steering problem - UCF21 LS400
Old 06-28-10, 10:50 AM
feejap
feejap's Avatar
Default Weird steering problem - UCF21 LS400
Hi everyone,
As you might have read in another thread, I've just acquired a 1998 UCF21 LS400.
Apart from the VSC problem as outlined in another thread, there is this weird problem RE the steering..
The steering is off (alignment booked), but what's worse is that the steering wheel basically does NOTHING while I turn it to-and-fro the 12 o'clock to the 2 o'clock position. I had a random mechanic check it out, and he turned the steering wheel while I looked at the wheel, minimal movement.. Once you turn beyond that, it's rather normal.
Alignment has been checked with a piece of string as my alignment shop is fully booked. Alignment is not off by much at all.. The mechanic tried to adjust the alignment which switched the dead zone from 12-2 o'clock position to 10-12 o'clock position..
I'm totally clueless about this problem...... Please help
Cheers,
Jeff
Old 06-28-10, 01:32 PM
PureDrifter
BahHumBug
PureDrifter's Avatar
something in the suspension is worn causing play. check the rack, universal joint, and tie rod ends. also check the strut rods and ball joints for play.
Old 06-28-10, 07:23 PM
feejap
feejap's Avatar
Car has just been inspected by my mechanic. He told me the rack mountings seemed to be loose on both sides. But as I see it the play is not so much that would cause the dead zone. And the shift of the dead zone from the 12-2 o'clock position to the 10-12 o'clock position just seems mysterious to me.. Well, it did that after the random mechanic tried to align my car with a piece of string.. Would that have something to do with the shift in the dead zone?
Old 06-28-10, 09:07 PM
feejap
feejap's Avatar
Mechanic just reported to me that the tie-rods has a LOT of play in them, so that might explain the mysterious dead zone in the steering, and perhaps the VSC problem too? My mechanic told me the car's wheel would physically be wobbling from left to right although the steering wheel isn't..
Old 06-28-10, 11:38 PM
PureDrifter
BahHumBug
yep. if its the inner rods i'd just have the whole rack rebuilt. outers alone will be fine though
Old 06-29-10, 02:50 AM
feejap
feejap's Avatar
Thx again mate for your helpful replies. Going to pick up the car now!! Fingers-crossed!!
PhilipMidd
06-25-18 08:46 PM
spitfire7
04-01-12 10:47 PM
basc300
Suspension and Brakes
10-28-08 09:22 AM
almost_g
11-16-07 07:26 AM
BrooklnLex
GS - 1st Gen (1993-1997)
10-12-06 04:51 PM
Quick Reply: Weird steering problem - UCF21 LS400
