Should I buy this LS400?
Here are the details:
130k miles
says the water pump seized and timing belt jumped, causing valve damage
good tires
good title
It's a 1993 model, he's asking just over $1200. If I can talk him down to $900, would it be worth it? I'd be sure to get the VIN and look up the maintenance history.
Also, and this is pretty important, I want to verify that the 1UZ-FE in the 1989-1994 models is a non-interference engine (meaning that there shouldn't be valve damage)
Thanks!
130k miles
good tires
good title
Thanks!
valve lash is a serious issue. one of the most crucial pieces of proper maintenance is the timing belt and water pump, so as to avoid this problem altogether.
that said, i would stay away from that car. there are other LS's out there for around that price range, maybe closer to 2 grand, with no serious problems. You'd be better served starting off with something in better shape.
Well all I can say is I picked mine up with 145k Miles on it had to doing the pump and belt 5k miles later and it cost me 1,500. Also mine was virtually spotless just a few minor dings and a little worn leather on the drivers seat.
Granted I know I got a screaming deal but who knows what it will take to get the valve damage and whatever else inside there that you can't see repaired....Though there technically shouldn't be since it is a non-interference motor.
Also
Also
here is a thread with some pertinent info for you :
http://us.lexusownersclub.com/forums...howtopic=44562
there seems to be some inconsistancy in information as well as first hand experience dealing with valve damage and whether or not the 1uz is truly non-interference or not.
Again my best advice remains the same, but good luck to you whatever you decide.
for me personally, I'd rather know for certain the internals of my motor were legit and did not need servicing later down the road that would be more than the car is worth.
one more, again, a bit of inconsistency and ambiguity remains: http://www.lextreme.com/forums/showthread.php?t=3202
if anyone can find a direct from lexus source to re-affirm that the models up to 95-97 were all non-interference that would be nice.
still, if that truly IS the case, and this guy still claims there was somehow valve damage, you might be looking at a more serious problem altogether with that car..
food for thought...
food for thought...
Yeah, I looked at several threads and could not get a definitive answer about the interference vs. non-interference properties of our motor.
I actually own a 1992 model in pretty great shape, so this car could potentially be used for parts. I was just wondering about being able to deal with this '93 (and maybe get it running again) since it is so cheap.
Thanks for all the replies!
yeah, there shouldn't be valve damage, so if there really is then run. I wouldn't suggest you get it unless you are really handy and experienced with cars. if it's just the timing belt and water pump that need to be changed, you could do that yourself and save a lot of money. if you have to pay someone else, you are looking at a $1000. there is always the risk of not hearing a car run, not knowing how the trans is and the suspension. so be carefully. Since you really have to ask us, I do just advice you to walk away.
paulv85
13
05-05-14 07:51 AM
Noelphilly
04-12-10 11:19 PM
