How do i build a motor ???????
ordered a motor for my 92 ls400 but received a motor out of a 95 ls400 so the mechanic wants another 1k to change everything over . what should i do to do the work myself ? old motor is still in the car and the new motor is on hoist ???? PLEASE HELP !!!????
ok . so what should so what should i do next ? the old motor was ran hot until it stopped . should i work on it or find another motor ? i already have got the parts :timing belt , water pump , thermostat , spark plugs , front crankshaft seal , rear main seal , oil pan gasket , spark plg wires , distibutors , rotors , drive belt , radiator hoses , serpentine belt , timing belt component kit , idler pulley tensioner , timing belt pulley .
Per your other thread, you paid $1k for it, send it back!!
https://www.clublexus.com/forums/ls4...t-stopped.html
1. As stated, have them pick up the incorrect motor and send you the one you ordered.
2. 1UZ motors are fairly not to expensive(as a whole) to find/get. In your other thread, you stated that the old motor has not been turned/cranked in over 4 years. Lost cause at this point,,just replace and you will be MUCH happier.
BahHumBug
send it back and replaced, or get your money back and buy from somewhere else.
