Rattling from sunroof
Old 05-28-10, 07:33 AM
amcdonal86
amcdonal86's Avatar
Default Rattling from sunroof
I am having this strange rattling sound from the headliner/moonroof shade then I have the shade open (sun coming in). Has anyone else had this problem? Closing it can get rid of the rattle, but it is a pretty loud one.
Old 05-28-10, 07:42 AM
7schulz
7schulz's Avatar
Yea my 95 is doing it I can't find where it's coming from b.c I'm always driving. I tried to shake some stuff up there while parked and can't figure it out. It's amazing how one tiny rattle in such a quite car can drive us OCD kind nuts.
Old 05-28-10, 08:02 AM
amcdonal86
amcdonal86's Avatar
So yours is the same way? when the shade is closed there is no sound, but when it's open, it's really loud?
Old 05-28-10, 08:13 AM
Thermactor
Thermactor's Avatar
Mine rattles too. Sometimes it's less when the shade is open, and more pronounced when the shade is closed.
It's always been that way.
Old 05-28-10, 08:21 AM
Brandicus
Brandicus's Avatar
I had this order, but opening/closing the sunroof with alittle force a couple times eliminated it for me. hasnt happened since
Old 05-28-10, 09:17 AM
7schulz
7schulz's Avatar
No it's louder with the shade open and less noticable with the shade closed but still there.
Old 05-28-10, 11:53 AM
RA40
Super Moderator
RA40's Avatar
The one gripe I've had with Toyota spanning back to my Cressida. Same damn rattle that they couldn't fix even a car made 12 years later. I'm used to it now having heard rattling for 20 years.
Old 05-28-10, 11:58 AM
Thermactor
Thermactor's Avatar
LOL, me too... evil '91 Cressida with the same sunroof rattle as the '96 LS.
Old 05-28-10, 12:55 PM
DanF
DanF's Avatar
Mine has a rattle from the sunroof as well, i was hitting around my headliner and i noticed that it is coming from the passenger side rear, I guess from around the track area. It seems to go away when i open the sunroof, and returns when it is closed
Old 05-28-10, 06:49 PM
j three
j three's Avatar
I have rattling from the moonroof as well. I think mine is different though. It sounds like two sticky pieces of plastic rubbing together. It sounds like it is coming from the track and not the shade. Or possibly from the mechanism itself.
Old 05-29-10, 02:27 AM
Jasbmo
Jasbmo's Avatar
any solutions?
Old 05-29-10, 07:06 AM
iamviolet
iamviolet's Avatar
mine also did that... i did the ghetto fix..i made a little rubber wedge from a pieces of rubber i had.. and slide it in there until it stopped. before i opened the sunroof i would casually remove it and replace it without anyone know what i was doing. my little wedge is about the size of aaa battery
Old 06-01-10, 05:57 AM
7schulz
7schulz's Avatar
Picture of where the wedge goes?
Old 06-01-10, 02:57 PM
Acidic
Acidic's Avatar
I fixed my rattle. Most are probably a broken rivet on the part that holds the track down to the plastic tub. There isn't that much metal back there to rattle so the possible sources are few... here is a thread I made, see pic #2:
https://www.clublexus.com/forums/ls4...your-head.html
It's not the best pic but that is where the track is attached to the pass rear side of the drain pan. They used rivets which apparently have a limited life span. I tried riveting it again but got fed up and bolted it down... this fixed the rattle 100% and took about 4 hours but that included breaking the sunroof glass... Be careful, there are ALOT of clips to break and at the back the hold downs are glued to the headliner which after all these years makes them weak. You can easily separate the mounts from the headliner and end up with a sag. A good epoxy can fix that problem.
Old 06-02-10, 02:09 PM
Snuke89
Snuke89's Avatar
yeah my 96 ls400 does the same thing. if i close the shade with a little force it does go away... for a while. i have not been fortunate enough to figure out wth it is yet though either.
Quick Reply: Rattling from sunroof
