New rear stabilizer link -- dumb question???
Old 04-28-10, 07:51 AM
blunden
blunden's Avatar
Default New rear stabilizer link -- dumb question???
I have a new pair of rear stabilizer links that I will install to replace the worn ones in my 91 LS400. As you can see in the photo, there is a bright green plastic bootie covering the rubber end. I've left one bootie on, and the other off so you can see.
Ok, here is the dumb question. Is the bootie to protect the rubber during shipping, or should it be installed with the link to protect the rubber from the elements? Needless to say, the originals don't have this.
Attached Thumbnails New rear stabilizer link -- dumb question???-stab_link.jpg
Old 04-28-10, 10:31 AM
lextech765
lextech765's Avatar
No way it will fit correct unless green is removed
Old 04-28-10, 12:28 PM
PureDrifter
BahHumBug
PureDrifter's Avatar
the green covers are there to protect the boot from being torn in transit.
Old 04-28-10, 08:04 PM
JimsGX
JimsGX's Avatar
Good luck getting the old links off if your doing a DIY. I ended up splitting the nuts down the middle with an air die grinder.
Old 04-29-10, 12:23 PM
nthach
nthach's Avatar
When I did my wheel bearings, CV boots, and most of the bushings I used a 14mm wrench on the nut+a 5 or 6mm Allen bit on the stud and a good soak in Penetro 90 prior to removal. Worked like a charm.
Old 04-29-10, 01:51 PM
JimsGX
JimsGX's Avatar
Mine wouldn't budge. The allen wrench stripped out of the end of the stud. The air grinder worked great though.
Spence89
IS C
03-20-17 11:27 AM
dk62vet
04-05-15 02:29 PM
416tt
11-20-13 10:31 AM
EKStoy
06-04-11 03:08 PM
Quick Reply: New rear stabilizer link -- dumb question???
