Driver Seat Replacement/Transplant from other Lexus
Old 04-09-10, 06:02 AM
7schulz
7schulz's Avatar
Default Driver Seat Replacement/Transplant from other Lexus
Are there any other Lexus seats that could be transplanted in place of the driver’s seat? Still use heated seat switch and power options. I would like something with more side bolsters too and have more tilt up in the front and more drop in the rear. At full max up in front and down in back I still hit my head on the head liner sometimes.
Old 05-10-10, 08:45 AM
7schulz
7schulz's Avatar
Looks like the IS300 has the same color seats. So does anyone know if they will fit or if it would be easy enough to make the transplant for just the front buckets? Which seat is better the Cloth and leather or the all leather.
OLD
Driver Seat Replacement/Transplant from other Lexus-ls400-9-small-.jpg
NEW??
Driver Seat Replacement/Transplant from other Lexus-is300-seat.jpg
Or
Driver Seat Replacement/Transplant from other Lexus-dcp_2318.jpg
Old 05-10-10, 11:58 AM
Och
Och's Avatar
Power and heat is very easy to rewire, but you'll lose memory seats, and most likely seatbelt tension reducer feature.
As far as fitting the seat itself, should be possible, but you will need to make some custom brackets to adapt the rails.
Old 05-10-10, 12:09 PM
7schulz
7schulz's Avatar
Not worried about memory I am the only driver of this car. What is the seatbelt tension reducer the button that moves the seat belt height is on the door.
Old 05-10-10, 12:18 PM
Och
Och's Avatar
No. In the LS model the seatbelts are setup to have less tension when they are buckled in than when they are not buckled in. There's a switch inside the buckle that activates the feature, obviously its not present in the IS seat.
Without this feature enabled you will find your seatbelt too tight and uncomfortable. The workaround would be to just wire it to the ignition, so that it would activate as soon as you start the car, but on the downside, if you unbuckle, the seatbelt wont automatically retract until you shut off the car.
This is what you should do, fasten yourself up and move around in the seat with the ignition on and off. You should feel the difference in tension and decide whether you could live with the feature disabled or use the work around.
Old 05-10-10, 12:22 PM
7schulz
7schulz's Avatar
Good to know, thanks for the heads up on that one.
Old 05-10-10, 12:29 PM
7schulz
7schulz's Avatar
Or would the IS250/350 seats be better and would this Cashmere color match? Is the cashmere just the Ivory renamed?
Driver Seat Replacement/Transplant from other Lexus-f-poywcwe-kgrhqmh-c0eve-hm1vbl5s0fgntq-_4.jpg
Old 05-11-10, 01:24 AM
Och
Och's Avatar
The color match will not be 100% thats for sure, but it will be close.
IS250/350 seats will be easier to find in good condition and they are much better quality to begin with.
Old 05-11-10, 03:17 AM
7schulz
7schulz's Avatar
Again thanks, I tried the seat belt tensioner and it seems to be associated with the ignition not the seat belt receiver. As soon as I turn the car off you can feel the belt pull back towards the b-pillar.
Old 05-11-10, 04:18 AM
Och
Och's Avatar
Its associated with both. Once you turn the ignition off, the tensioner releases, and whether the belt it buckled in or not, it will have increased tension.
When the car is running however, tension reduces once you buckle in.
subiepunk
General Classifieds
09-18-15 06:35 PM
Piece350
Canada
06-08-15 04:42 AM
Iparkcars
06-24-13 05:53 AM
tidus12345
05-09-13 09:12 AM
LuxuryGS3
01-03-12 06:36 PM
Quick Reply: Driver Seat Replacement/Transplant from other Lexus
