Front Crank seal
Old 03-08-10, 03:20 PM
Acidic
Acidic's Avatar
Default Front Crank seal
I'm doing the timing belt this weekend and I'm having trouble finding the front crank seal. I found the cam seals locally but no luck (including sewell) on the front crank seal... anyone know where I can find one? A chain store would be nice so I can get it locally.
Also do I need all of the timing cover gaskets?
Old 03-09-10, 04:45 PM
PureDrifter
BahHumBug
PureDrifter's Avatar
given the timing marks that are really only found on the oem timing belt, you may want to "splurge" on the OEM belt too.
Old 03-09-10, 05:17 PM
Acidic
Acidic's Avatar
water pump, timing belt, o-rings, and tensioner are lexus parts... the idlers and seals are aftermarket
Old 03-09-10, 05:19 PM
Acidic
Acidic's Avatar
Originally Posted by Thermactor
Hey man, I'm doing the crank seal and timing belt on my '96 right now too. It took three hours to remove everything, with crappy hand tools! Tomorrow I'm picking up the timing belt from AutoZone and will try for the front crank seal at the local Toyota dealer. The crank seal from a 2000-2006 Tundra will work in our car, and should not cost more than $10. The Lexus dealer will charge $15-17 for the same part because they're dicks.
So try your Toyota dealer and ask for a 2000 Tundra front crank seal.
thanks for the tip! I plan to take it all apart Friday afternoon/evening and reassemble on Saturday... I'm not doing ignition parts till later (cap, rotor, wires and plugs)...
Old 03-10-10, 05:18 AM
5ofakind
5ofakind's Avatar
Most Lexus parts you can find at the Toyota dealer......& they are cheaper.....
Old 03-10-10, 05:51 PM
Acidic
Acidic's Avatar
It doesn't seem like they would be that hard... but I haven't pulled apart one before... Maybe I'll go shopping around and see what I can find locally... OEM ones are spendy and I don't have time to wait for parts from sewell
ruger
06-07-16 03:33 AM
monrovea
04-10-12 05:29 PM
sktn77a
RX - 1st Gen (1999-2003)
08-16-11 12:45 AM
Vadim540i
SC- 1st Gen (1992-2000)
11-28-10 11:42 AM
cocora64
05-30-08 04:43 AM
Quick Reply: Front Crank seal
