Revere Polarity Jump Starting 92 LS400. Radio & More Wont Work
Old 02-02-10, 01:41 PM
black_LS
black_LS's Avatar
A friend did this on his first gen.. he had a fried relay somewhere too.
Old 02-02-10, 02:11 PM
VIPking
VIPking's Avatar
did you know where exactly I can't find anymore blown fuses???
Old 02-02-10, 02:22 PM
VIPking
VIPking's Avatar
Originally Posted by steve2006
I second the last post Dome fuse number 20 in drivers kick panel fusebox rated at 10A.
I checked all these fuses and their all good. Is there other fuses somewhere else in the car????
Old 02-03-10, 07:50 AM
VIPking
VIPking's Avatar
Mornng bump.
Old 02-03-10, 10:00 AM
avalon42
avalon42's Avatar
Your "Green" Relay in the ENGINE compartment is fried. Try changing it, but I think honestly with the smoke it could have shorted the wiring underneath. You'll have to remove the standoff bolts to inspect.
Old 02-03-10, 12:39 PM
VIPking
VIPking's Avatar
I fixed the problem it was the green relay you mentioned I put it on the wrong way when I was trying to find the blown fuses. I remember the green one was the first one I pulled after the jump start incident. But I have all my functions back. Thanks you for your help and everyone who attemped to help me. Thank you all.
Old 02-03-10, 08:39 PM
willhickey
willhickey's Avatar
how could you tell it was the green one avalon? you are a smart one you are
Old 02-03-10, 09:05 PM
avalon42
avalon42's Avatar
To the OP, you're welcome.
And, no, I'm not. Stupidity and experience more like it. I was undoing the wiring harness in the engine bay because I have a lot of electrical taps I run for my electrical fans. I didn't tighten the harness all the way and had a problem with these functions. Tightened it and all functions were restored. Trial and error.
Old 08-01-11, 05:42 PM
MrAxe
MrAxe's Avatar
I know this is a dead thread, but I thought I'd give it a shot on the off chance either VIPking or avalon42 have some insight..Same issue on Lexus LS400 - except ONLY issue after battery replacement is stereo head unit. No power at all coming to unit. I checked/changed the fuse under the hood, but was unable to locate fuses inside the car. I pulled the kickpanel on driverside up, and behind E brake, under carper were wiring harnesses but no fuses? Where is the other fuse entry?
I actually took my car to MIDAS today to get an oil changed, and asked them to see if they could fix it, i was literally told "you should take your car somewhere where they can check the wiring" ..which brought me here - any help appreciated. everything else seems to be working normally.
Old 08-26-14, 04:10 PM
darelicte
darelicte's Avatar
So I did the exact same thing as OP, after replacing the 120A alternator fuse, there are a bunch of things that aren't working now. My power locks, key fob, dome lights, radio and the steering wheel tilt all don't work now. I have checked the majority of the fuses and they seem fine. I tried taking out that green relay that fixed the problem for the OP, and that seems fine but I don't know how to tell if that is blown. Anyone else think of anything?
Old 10-13-14, 10:33 PM
darimura
darimura's Avatar
I am having the same issue. It seems that all the items listed in the under dash drivers side panel are the items that are not working, another words what relay or fuse is supplying the power to the drivers side under dash panel??
johnls400
07-18-15 06:02 PM
Baggedls
08-15-13 10:53 AM
tvonhaefen
05-30-11 09:50 PM
Stevens226
SC- 1st Gen (1992-2000)
08-31-08 02:04 AM
BlackoutGS
01-12-08 08:00 AM
Quick Reply: Revere Polarity Jump Starting 92 LS400. Radio & More Wont Work
