96 drivers seat w/memory - ECU problem?
Old 12-07-09, 09:14 AM
mkaye
mkaye's Avatar
Default 96 drivers seat w/memory - ECU problem?
i took the seat out to fix the heaters
i put the seat back and i can't any of the motors to work
the lumbar works (doesn't go thru ECU)
i hear the relay click inside the ECU when i move 1 of the manual switches
i have voltages in all the right places (all fuses are OK)
i checked all the connections in the seat in case i knocked 1 out, but they are all seated correctly
i can't believe that it is just a coincidence that the ECU decided to pack it in
mark
Old 12-07-09, 10:20 AM
mkaye
mkaye's Avatar
OK, i guess i need a long talk with my mechanic
when i had the seat out i noticed that the headrest wasn't connected, so i connected it (i thought they missed it when they last worked on the heaters)
i disconnected the headrest & now i have motion back
i think the sensor must be feeding bad info to the ECU & it refuses to do anything
i'll leave it for a warmer day (next spring)!
mark
Old 12-22-09, 02:33 PM
Thermactor
Thermactor's Avatar
If you want a seat ECU, I have a spare one that I'm not using, you can have it for fifteen dollars. I tested it today, it works.
Indianajef
12-11-19 08:56 AM
2KHarrier
RX - 1st Gen (1999-2003)
10-03-14 11:35 AM
zxaaron
SC- 1st Gen (1992-2000)
06-23-12 09:59 PM
carlmatthe
Performance & Maintenance
03-13-08 05:38 AM
Quick Reply: 96 drivers seat w/memory - ECU problem?
