Fitment Help
Old 12-03-09, 11:09 PM
V.I.P LS4
V.I.P LS4's Avatar
Exclamation Fitment Help
hey guys just needed some help on what size spacers to get ?
[IMG][/IMG]
[IMG][/IMG]
[IMG][/IMG]
Old 12-03-09, 11:24 PM
LiCelsior
Retired
LiCelsior's Avatar
looks like 5F 10R. possibly 10 f also.
Old 12-03-09, 11:50 PM
j three
j three's Avatar
Hey bro, give the experts your wheel and current tire specs. That will probably give them a better base to go off of. Also get some new shots taken close in an upward angle from where the rear quarter panel and bumper meet, by or under the chrome trim. Kind of similar to your first pic. And the same for your front end. The pro's probably won't need pic's but hey, your car is hella clean so why not show us some more! LOL!
By the way are you rubbing anywhere front or back? I am running 245/35/20 on a 9 +38 (99LS) and am rubbing slightly on freeway on ramps on the upper inner area. No rubbing out back with 275/30/20 on a 10.5 +45.
On the next set of tires I want to Run Hankook V12's and want to go with 285/30/20 rear but the bad news is I want to run 245/30/20 up front but they don't have that size, they have 245/35/20, 255/30/20 and 235/30/20. Will I rub more with the 255/30's due to width or am i currently just rubbing due to height and will be ok with 255's? I would rather not stretch it more with the 235/30's due to L.A. streets, but I may have to. I may also run some spacers since I have to get some body work done, what size should I run with the wider of the two setups?
Sorry for the thread jack V.I.P but since it is close to what you need and the pro's will be on here I didn't want to start a whole new thread if it could be mentioned here. Back on topic
Old 12-04-09, 02:34 AM
PureDrifter
BahHumBug
PureDrifter's Avatar
245/35-20 on the front of the 2LS will rub on the liner during compression and at lock when parking.
try running 225/35-20, i run it on my 9j fronts with no rubbing on the liner at all, plus its relatively decent protection.
OP: give us wheel specs and tire sizes, as well as where you're rubbing right now.
Old 12-04-09, 04:13 AM
j three
j three's Avatar
Thanks P.D. I knew you would hit this thread up with the quickness! LOL! I may be lucky but I don't rub while parking. By the way I remember seeing your rear tires but do you have a nice pic of the front?
Old 12-04-09, 06:22 AM
PureDrifter
BahHumBug
i actually dont have any pics of my recent tire setup, the last pics i posted (a LOOOONG time ago) were when i was running 245/35 fronts and 255/35 rears.
i'll get some pics up in the next week or two after finals.
Old 12-04-09, 09:27 AM
LiCelsior
Retired
LiCelsior's Avatar
usually means in 3-6months.
Old 12-04-09, 10:02 AM
V.I.P LS4
V.I.P LS4's Avatar
[/IMG]front of the 2LS will rub on the liner during compression and at lock when parking.
OP: give us wheel specs and tire sizes, as well as where you're rubbing right now.[/QUOTE]
[IMG][/IMG]
[IMG][/IMG]
ill put up tire sizes a lil later i forgot the sizes
i only rub in the Front right know on a andle turn or say pulling out of somewhere, im going to get the rear rolled , i dont know where to get the front done i dont want to try it myself cause ill mess up the paint prlly . The rubbing in front occurs just on that lip on the fender its not really bad but it took off the paint on the inside
Old 12-04-09, 12:20 PM
j three
j three's Avatar
Dang, I just remembered that you recently got your ride painted too. That is the exact pic I was looking for. It looks like a 10 to 15mm spacer in the rear. You basically have a whole lip worth of real estate to work with. Also have you taken the little plastic trim off of the lips in front? My tires rubbed the lips up front ind rolled them nicely LOL! I was forced to take my trim off when the fender rolled since it bent, but no more rubbing there now. It's only two screws I think.
Old 12-04-09, 12:49 PM
V.I.P LS4
V.I.P LS4's Avatar
Talking
Haha ya i did paint it recently , also last week i painted my grill gloss black looks real nice , but i went iceskating and was looking at some females while pulling into a parking spot and cracked my front bumper lmao, i almost cried. I have my winter wheels on now, and i need to complete a few more things in the summer and my project will be done . overall it was a pretty quick build and i am satisfied with the results . I do have to take apart the intake manifold to get to the damn EGR pipe that i cracked while replacing my starter. I also have a oil pan gasket i have to reseal and im going to change all the gaskets on the egr and so on. Fog lights have to be mounted , new tires needed in rear do to camber lol, windsheild chrome trim was messed up when they put in my new windsheild, and all the bushings in the suspesion . Last but not least the fender rolling and spacers which im gonna buy soon, and buff the whole car.
"o and to answer your other question i took off the trim on front and back it gave me a lil more clearance "
Old 12-04-09, 01:54 PM
PureDrifter
BahHumBug
doing it visually using PICTURES isnt goiing to end well.
at the VERY LEAST we need some wheel specs....
Old 12-05-09, 07:25 AM
j three
j three's Avatar
I see that they come in 20/10 +25 or +40 for the rear and 20/8.5 +20 or +35 front.
Old 12-07-09, 11:07 AM
V.I.P LS4
V.I.P LS4's Avatar
Fronts 225/35 zr20
Rears 245/35 zr20
Old 12-07-09, 02:22 PM
PureDrifter
BahHumBug
...wheel specs...ie-wheel widths/offsets...
Old 12-07-09, 05:46 PM
V.I.P LS4
V.I.P LS4's Avatar
ahh my bad missread the post,
front 20x8.5 lip size, 2.5 offset 35
rear 20x10 lip size, 5.0 offset 40
heres a link http://www.torkwheels.com/wheels.html , im not a hundred percent sure on the offset theres two dif types the other is front offset 20
rear 35 . Sorry not familiar with these things
Quick Reply: Fitment Help
