Aftermarket stereo install retaining factory speakers in 1995 LS400
No sweat.
The sub is in the center of the rear deck behind the seats. The cover pulls straight up with a bit of effort. It's an 8 inch sub, but it sounds pretty good for its size.
There's a hole under the sub that can be accessed through the trunk if you take the shroud off, but it's not useful in any way. You can remove the sub and work on it from the top.
There are foam repair kits if it's cracked, but mine was in good shape.
I'm not having much luck with my 95 LS with nakamichi sound oem. I am installing a Pioneer AVIC x940bt and I wired it by pulling the wiring back from the amp under the passenger seat, back to the console behind the radio. I hooked up the speaker wires and grounded r3c pin 14 to the stereo harness, connected r3c pin 1 to stereo harnesspower, and then hooked s13a pin 6 to the stereo ignition switched 12v+. Anything I'm missing? Thanks in advance!
Okay, so i guess I'm only one having trouble the memory wire (acc wire)? My radio settings won't save and my factory sub won't turn on either but I'm going to get an aftermarket sub anyways so I'm not worried. But I don't want to readjust my radio around everytime I start the car, help??
shawnlexus
05-25-24 10:59 PM
jjacks16
03-03-11 01:21 PM
