ucf10 ucf21 engine swap
Old 09-15-09, 09:55 PM
missin_4
missin_4's Avatar
Default ucf10 ucf21 engine swap
i was wondering if the engine from a ucf10 will swap in and work on a ucf21?
Old 09-16-09, 02:12 AM
trukn1
NELOC Mod
trukn1's Avatar
IIRC,, sizewise it will fit however you will also have a boat load of wiring to do. Different wiring harness as well as you will need the ECU from the 21(Different ECU as well). It CAN be done, but not without some work in order to do so.
Old 09-16-09, 02:17 AM
PureDrifter
BahHumBug
PureDrifter's Avatar
im not 100% but the sump positions may be different for the VVTi engines, so in that case, No.
god only knows why in the hell you'd want to replace the VVTi engine with an early 1uz....mind you, i'm guessing since the UCF21 could reference to either the 95-97 OR 98-00 since it's a chassis code that doesnt delineate the minor change.
Old 09-16-09, 05:50 AM
missin_4
missin_4's Avatar
thanks guys! i was asking because i found a ucf21 with no engine and wanted to put mine in there
Old 09-16-09, 09:58 AM
fourthmeal
fourthmeal's Avatar
Sounds like a 2JZ candidate possibly. Yes, I know its not easy, but hey...
Old 09-16-09, 12:47 PM
PureDrifter
BahHumBug
still havent told us what year it is. UCF21 could be either, the "1" doesnt designate generation.
lochone112
Performance & Maintenance
01-31-17 10:39 AM
13loody
28
05-14-07 02:32 PM
Z28owner
36
01-04-07 02:07 PM
soarerxx
11-07-06 12:48 AM
Quick Reply: ucf10 ucf21 engine swap
