DIY Engine and Transmission Bushings Replacement
Old 09-24-09, 09:47 PM
Garage7RP
Garage7RP's Avatar
Smile To naes...
If you can change your suspension by yourself...
I think you can perform this work .
Originally Posted by naes
what's the level of this maintenance work?
Old 09-27-09, 05:59 PM
Lexozz
Lexozz's Avatar
I am definitely in need of tranny mounts. I'll be doing the myself, thanks for the write up?
Old 09-28-09, 01:53 PM
qewani1
qewani1's Avatar
how do i know if mine needs replacement or no?
Old 09-28-09, 05:58 PM
Garage7RP
Garage7RP's Avatar
Smile To gewani...
If your car is experiencing shaking on the gear shifter and excessive engine vibrations.
Old 07-08-10, 12:00 PM
johnnyg66
johnnyg66's Avatar
Anybody know what the torque is on the tranny mount bolts?
Old 08-02-10, 08:01 AM
billydpowe
billydpowe's Avatar
We just replaced the engine mounts in our 99 LS
the old ones came out in two pieces, both of them was broken.
tranny mount was replaced earlier, now I have a good solid ride.
took about 3 hours.
Attached Thumbnails DIY Engine and Transmission Bushings Replacement-100_1759.jpg
Old 08-06-10, 07:47 AM
qewani1
qewani1's Avatar
aha ok thanks
Old 08-06-10, 05:14 PM
Mega
Mega's Avatar
this will be done on my car in the next month or two.
thanks for the writeup.
Old 09-28-10, 03:37 PM
dl11
dl11's Avatar
Originally Posted by b8b
I found the OEM parts by calling http://www.oemlexusparts.com
$104 for the front (each) and $37 for the rear. Not bad. I found someone locally that will install them for $150.
Is there a way to tell if it is Tranny only or also engine? Tranny looks so easy
Sorry to revive an old thread but did you tell them you were with clublexus? Sewell online lists it at 126 each for the engine and 84 for the transmission.
Edit:Nevermind, just registered account to Sewell Parts. Much better deal now.
Old 09-29-10, 02:15 PM
qewani1
qewani1's Avatar
could some one post DIY with photos....am newbie & want to try doing the change.
Old 02-04-11, 12:09 PM
johnnyg66
johnnyg66's Avatar
Did my tranny one today. Got my oem part off ebay for $36 bucks. But you do have to jack up the tranny when you put it all back together. Don't know if i want to try the engine ones.
Old 02-27-11, 10:31 AM
silos5
silos5's Avatar
about changing engine mounts: you need to take the AC/heater valve off, otherwise you brake it lifting the engine. I broke mine, damn expensive piece of plastic
Old 03-19-11, 10:08 AM
kuziwk
kuziwk's Avatar
sorry to bring this post up again, but when you remove the power steering rack doesnt doesnt it leak from the reservoir?, do you first drain the reservoir?
Old 03-19-11, 11:11 AM
silos5
silos5's Avatar
I didnt remove it, but it was hard to squeeze the mount on the driverīs side, took my nerves
Old 03-20-11, 01:16 AM
kuziwk
kuziwk's Avatar
This looks like a big job too. So you dont need to remove the power steering rack? I changed the distributer caps and rotors, spark plugs, wires....That took me a long time and i had to remove alot of components via lexls tutorial. Im just not sure if i have the skill for the mounts, how hard are they to replace compared to the distributer caps and rotors?
Quick Reply: DIY Engine and Transmission Bushings Replacement
