Power steering pump knock?
Old 08-18-09, 10:21 PM
91LS400LEX
91LS400LEX's Avatar
Default Power steering pump knock?
I mentioned before that my 91' LS had a knocking sound that concerned me. I had thought it was a rod, but I was told this was unlikely on the 4.0L engine. I later had a major clunking that turned out to be my fan bracket bearing. I thought maybe that was the part causing the noise in its early failing stages. I had that replaced with a OEM Toyota part, but the knock was still there, so apparently not. Its been like that for awhile, but its bothering me now. It can only be heard sometimes at idle, but mostly when accelerating lightly when the engine is between 1200-1600 rpms. I cant hear it unless the radio is off. I have a leaking PS pump and wondering if this noise could be coming from the worn out pump, or?
Thanks for any info.
Old 08-18-09, 11:04 PM
AzHotLS
AzHotLS's Avatar
as i said over at LOC, your valves need adjusting.
Old 08-18-09, 11:27 PM
91LS400LEX
91LS400LEX's Avatar
thanks.. got your message and replied.
astowell
01-11-21 02:29 PM
suprasoup
Performance & Maintenance
01-10-15 03:37 PM
voleduy
IS - 1st Gen (2001-2005)
11-03-11 02:43 PM
damon
10-26-05 12:50 PM
Pagong
02-12-04 09:41 AM
Quick Reply: Power steering pump knock?
