Sunroof Adjustible?
Old 06-11-15, 02:12 PM
  #31
johnnyg66
johnnyg66's Avatar
Originally Posted by dicer
My belief on the moon roof and even the trunk seal is to keep the seals and the surface they contact clean.
I have not tested the one roof, the car sits outside and just didn't want to chance a problem in the wet weather when I did the fix. When ever you use it I'd take a damp cloth and wipe the opening clean before closing it, lots of dirt and junk seems to collect there. Same goes for all the rubber seals, I hate leaks.
Glad mine sits in a garage and is not my daily driver. But I do use a good protection on the seals.
Old 06-12-15, 02:07 AM
  #32
dicer
dicer's Avatar
What do you use?
Old 06-12-15, 09:11 PM
  #33
johnnyg66
johnnyg66's Avatar
What do you use?
https://www.clublexus.com/forums/ls4...oor-seals.html
Old 06-12-15, 09:49 PM
  #34
dicer
dicer's Avatar
I'd rather use something like Mequires rubber protectant, or 303, or Ruglyde
Old 10-24-15, 07:01 AM
  #35
python
python's Avatar
having an issue with wind noise and also it seems like i can push up on the back end of the glass when its closed and it lifts up...is this what u guys are referring to when u say to use shims?
Old 10-24-15, 12:28 PM
  #36
dicer
dicer's Avatar
The rubber seal should very slightly be above the roof line. The metal shims do that. The other shims or spacers are the wire ties that help expand the rubber seal closer to the opening in the roof (the sides, front and rear).
Old 10-25-15, 08:21 AM
  #37
python
python's Avatar
anyone have pics on exactly where to place the shims to raise the back part of the glass to level it out and hopefully seal the wind.
Old 10-25-15, 12:01 PM
  #38
dicer
dicer's Avatar
Remove the plastic side covers and you will easily see the shims that are between the moon roof frame and the frame that is part of the open close mechanism, just loosen the nuts to add more. To remove the plastic side covers I use a plastic pry tool (harbor freight) and you don't want to go too deep just pry on the very edge of the plastic cover about 2 inches from front and rear that is about where the clips are that push into the moon roof frame. If you go too deep in it hooks the metal frame and that will not remove the plastic.
And yes I pry against the glass and use other hand to pull down on it.
Old 10-25-15, 08:22 PM
  #39
python
python's Avatar
ok thank you
LexusFan09
10-01-12 04:48 AM
Stu
09-18-10 08:15 PM
sjnmsn
07-17-06 06:12 PM
The Ikon
Maintenance
04-30-01 10:09 AM
Quick Reply: Sunroof Adjustible?
