Im still getting 10 mpg!! What else can i do?
Old 04-09-09, 07:33 AM
LiCelsior
Retired
LiCelsior's Avatar
wheres the fuel pressure reg on this car?
Old 04-09-09, 09:27 PM
KingNasGS4
KingNasGS4's Avatar
Originally Posted by avalon42
Were you having the 10 MPG problem BEFORE changing the ECT, or AFTER? Also, if you are having so much problems with it, did you try an OEM ECT yet? If you change it and it works, then knock it.
Others and myself are having good luck with the Autozone sensor.
I stated in my first post that I was getting 10 MPG before AND after changing the ECT sensor. i never blamed low mileage on the ECT sensor. I just stated I even changed it and i was getting same results, in addition to the high rpm problem that i got AFTER I changed the sensor.
and thanks I will see if I can get my mechanic to check the fuel pressure regulator out
Old 05-10-09, 07:37 PM
margarita
margarita's Avatar
Originally Posted by UofACATS
Check the vacuum line to your fuel pressure regulator.
i have the same problem (really low gas mileage). is this something i can check myself? where is it located?
Old 05-10-09, 07:40 PM
margarita
margarita's Avatar
that is what i am worried about. spending $150 to change out the ECT (i do not know how to do this myself...not a mechanic...not set up to that kind of thing) and then not having it solve the problem. if you buy an oem ECT and it does work/help, please post back here. i guess i can look at your laundry list to get some ideas about what i can try as well. thanks.
Old 05-10-09, 07:48 PM
LiCelsior
Retired
LiCelsior's Avatar
the fuel pressure regulator is in this pic, to the left of the red circle.
the write up on the testing is also lengthy via alldata...imma try to see if i can email it.
Old 05-13-09, 11:37 PM
1995LS400
1995LS400's Avatar
i drive my second gen LS hard all the time and have at the worst 17.5 mpg, at the best 21.5 mpg, half city, half highway driving.....but on long road trips, i get about 23.5 mpg.....this car is great, better than my old Acura Legend 91' V6, that thing ate gas..!!
Johnhav430
12-17-16 11:26 AM
Farazmad
ES - 5th Gen (2007-2012)
36
07-19-14 05:18 PM
scgal
Hybrid Technology
20
08-20-12 07:00 PM
xHartawann
HS 250h Model (2010-2012)
48
05-07-10 02:22 AM
mercy0171
08-26-06 03:45 PM
Quick Reply: Im still getting 10 mpg!! What else can i do?
