light on the dash!
Old 01-29-09, 06:10 AM
python
python's Avatar
Default light on the dash!
i just had my windows tinted and now the light that shows the little car with the brake lights glowing out of the back is on....when i shut my car off and restart it the light goes off until i hit the brake pedal, i checked all my lights and they are working fine, even the 3rd brake light....i know the guy sprayed water inside my car and down the back window, he even had my rear head rests off as well as the subwoofer cover.....any ideas would be greatly appreciated guys..thanks
Old 01-29-09, 06:41 AM
19psi
19psi's Avatar
all brake lights are working? there are 2 inside that 3rd brake light. make sure they'r both on.
Old 01-29-09, 06:50 AM
python
python's Avatar
ok i will thank you! i didnt even think of that...i just saw it lighting up against my back window
Old 01-29-09, 10:59 AM
trukn1
NELOC Mod
trukn1's Avatar
Yup,, having the windows tinted should havenothing to do with a bulb being out. As 19PSI suggested, you may have 1 of the 2 bulbs burned out or misplaced, or not making god contact. Could have been jarred loose when they removed it to tint the window.
Old 01-29-09, 11:27 AM
PureDrifter
BahHumBug
Forum Moderator
PureDrifter's Avatar
trunk hinge harness..
Old 01-30-09, 07:53 AM
python
python's Avatar
bulb is out on my 3rd brake light....have to let my windows sit for a few days, then ill replace them
Old 01-30-09, 02:29 PM
trukn1
NELOC Mod
trukn1's Avatar
You can get to them while the windows are setting. Just pop the subwoofer cover up and pull backwards and that whole assemble will come with it. Won't bother the window at all.
Old 01-30-09, 10:02 PM
akitomk3
akitomk3's Avatar
One of my 3rd brake light is out but i cant pull that cover out. It seem to be really tight in there. I dont want to break any clips but what is the best way to get that cover out.
Old 01-30-09, 11:58 PM
trukn1
NELOC Mod
trukn1's Avatar
Take a flat head screw driver and CAREFULLY pry under the corners of the subwoofer cover. You will see where the clips are, running along the back side. Once you have one released, the rest come no problem. It is a reallly tight fit, so be careful. This will help you remove the cover,,,http://www.lexls.com/tutorials/light...stoplight.html
Old 01-31-09, 05:27 AM
python
python's Avatar
thanks trukn
Old 01-31-09, 08:59 PM
avalon42
avalon42's Avatar
Yup, I had my windows tinted 2 months ago and the bulb just died. Something in that baby shampoo/water mix those tint guys use that bulbs don't like.
Old 02-01-09, 03:58 AM
python
python's Avatar
well i went to work yesterday, i had a guy change the bulbs for me, they were 912's, i handed him the wrong bulbs...i gave him 921's, the guy put them in anyways, the lights work but the anoying light is still on the dash....
Old 02-01-09, 12:08 PM
avalon42
avalon42's Avatar
921s are the correct bulb, according to what I pulled out of my tail lights. I placed them in there, and the dash warning light went out.
Old 02-01-09, 04:38 PM
trukn1
NELOC Mod
trukn1's Avatar
Check the wire harness on the trunk hinge. May have a wire gone bad on you.
Old 02-01-09, 04:56 PM
python
python's Avatar
i looked at it the harness, peeled back by the hinge and there is a little plactic box lookin piece that the wires run through, should i ohm test the wires or peel farther back?
has this issue been known to effect the way the car runs?
Quick Reply: light on the dash!
