Calling All Gen 1 Experts
Old 01-26-09, 07:44 AM
ur2slow1
ur2slow1's Avatar
Default Calling All Gen 1 Experts
I've got a 1991 LS400 w/ 81K miles and here's my problem. When driving and especially when coasting I feel a "rubbing" or slight vibration through the steering wheel and gear selector. I've already replaced the trans mount but the feeling is still there. Do you guys think it could be motor mounts or something else. Thanks in advance for your input.
Old 01-26-09, 07:59 AM
avalon42
avalon42's Avatar
Does it intensify with speed or remain constant from low to high speeds?
Old 01-26-09, 08:19 AM
Bradster
Bradster's Avatar
Front end/wheel/brake issue? Coasting w/rubbing problem would seem to eliminate motor mounts as the source..
Old 01-26-09, 08:40 AM
ur2slow1
ur2slow1's Avatar
It seems to remain constant, not really affected by speed. We have determined that new control arm bushings are needed and I've got them on order. Could it be the worn out CA bushings causing the problem. I guess we will see soon enough. Thanks
Old 01-26-09, 11:19 AM
PureDrifter
BahHumBug
PureDrifter's Avatar
wheel balance perhaps?
or rear trans mount/prop shaft bushing?
Old 01-26-09, 05:40 PM
91 LS400
91 LS400's Avatar
ya PD prop shaft bushing.....get the arms fixed
Old 01-26-09, 06:21 PM
ur2slow1
ur2slow1's Avatar
Ok guys, no flames please, but WTF is a Prop Shaft Bushing. I have searched and don't find much information at all on where/what it is or how hard and expensive it is to replace. Thanks
Old 01-26-09, 06:36 PM
molexGS400
molexGS400's Avatar
without previous posts.. i would say trans mount / engine mounts. make sure the bracket attaching the exhaust to the transmission housing is not cracked or loose.
Old 01-26-09, 06:48 PM
91 LS400
91 LS400's Avatar
37511 COUPLING, FLEXIBLE
37511‑50010 UCF10; FR 1 $374.27
37511‑50020 UCF10; RR 1 $270.85
t o y o d i y dot com
Y cant i put this link here? http://www.*******.com/parts/
Old 01-26-09, 11:47 PM
trukn1
NELOC Mod
trukn1's Avatar
Prop shaft(propellar shaft) AKA Drive Shaft bushing is what they are referring to.
Old 01-27-09, 05:38 AM
Bradster
Bradster's Avatar
The 2 bushing/gaskets/couplings listed above retail for 214.00 each...Also new part #'s apply...
Old 03-23-09, 04:15 PM
JimsGX
JimsGX's Avatar
I also have a 1991 LS400 with 82k miles with a similar problem. I just had the complete propeller shaft replaced at the dealer. Didn't help... It is most noticeable when decelerating within specific speed ranges. 25-30mph and 45 to 55mph. I also recently replaced my upper and lower control arm bushings and transmission mount. All to no avail...
Have you had any aftermarket parts put on your vehicle lately (other than cosmetic)? How long have you been having the problem for? Have you had any luck identifying the problem?
My car cruises effortlessly on the highway (70-80mph). Every wheel has been checked and rechecked for balance. I even put four new Michelin's on the car and the same vibration is there afterwards. It also has all new brake pads and rotors (all OEM Parts)...
It feels like its coming more from the back than the front but its very difficult to tell for sure. The only vibration felt through the steering wheel is very slight when its happening... Definitely isolated enough through the steering wheel to rule out it being the root cause.
Old 03-24-09, 08:25 AM
ur2slow1
ur2slow1's Avatar
Sorry, but I gave up on the mystery and sold my 1991 and replaced it with a 2000 LS w/ 82K miles. Let me know if you have any luck.
Old 03-24-09, 10:00 AM
EastWind
EastWind's Avatar
if you have any suspension problem, take it to your shop. if you have a good mechanic they will take it up and figure out what it is. it could be a whole bunch of things. I use one shop for my lexus and they will look at it for free. as a matter of fact, i am getting one lower ball joint, wheel bearings and upper control arm changed. but they only way to know what was needed was to have them lift it up, and inspect it, which they did for free. good luck
Old 03-24-09, 12:58 PM
JimsGX
JimsGX's Avatar
Unfortunately, the Lexus dealer was the one who did the daignostic ($105)and recommended I replace the Prop Shaft to fix the vibration...
After driving it some more today, I must say that the overall smoothness of the vehicle is better, but I still have the same vibration, especially at 25-30 and maybe a little less now between 45-55....
I've been dealing with it for a year and a half now. This is a third Lexus (play) car for me. I may wait a little longer to see if it gets any worse on its own and therefore easier to identify as time goes on...
Now I'm leaning towards the differential bushings... From inspection, they can't find anything else wrong.
Quick Reply: Calling All Gen 1 Experts
