Supra LSD onto LS400, CONFIRMED!
Old 12-31-08, 09:14 AM
Kingsoup
Kingsoup's Avatar
Default Supra LSD onto LS400, CONFIRMED!
http://www.lextreme.com/forums/showt...7711#post97711
I hope this isn't a repost, anyways the guy has a 91 Celsior
Fitting the prior to 96 Series B Torsen LSD from the mk4 Supra TT, looks like he had to:
1. Switch Rear cover from factory Diff to move mounting bolt location
2. Drill out two new mounting holes on front of subframe, welded nuts
3. Relocate parking brake cables
4. Adapter plate between rear of driveshaft to LSD input, not a lot of detail on this
5. Stock axles bolted right up, nice eh?
All in all not bad! I think those Diffs sell for under 400$ on supraforums, a little pricey. Mostly I want one for better winter performance, and its nice to hang it out in the rain once in a while.
So there it is! Comments?
Old 12-31-08, 09:53 AM
LiCelsior
Retired
LiCelsior's Avatar
someone on here did it too. but this car is crazy, the size on the whipple is insane.
Old 12-31-08, 10:52 AM
RA40
Super Moderator
RA40's Avatar
Those guys from down under are extreme. I learned a lot by reading about their mods and found out how much cross compatibility there can be among Toyota's from a range of years. Give them a few more years to get working on the later generations.
Old 12-31-08, 12:14 PM
MEANDAFAKA
MEANDAFAKA's Avatar
wow, supercharger with two throttle bodies, that is gonna be a beast.
Old 12-31-08, 01:35 PM
PureDrifter
BahHumBug
PureDrifter's Avatar
heh, this is what has been already confirmed
1st gen LS need to have custom mounting points and driveshaft mods.
Old 01-01-09, 10:16 AM
Thermactor
Thermactor's Avatar
What to 2nd gen LS owners need to do?
Old 01-01-09, 01:47 PM
PureDrifter
BahHumBug
95-97 owners are in the same boat as the 1st gen, same basic diff mounts.
98-00 should be able to use mkiv diffs as long as they swap over the rear diff cover/mounting plate.
gs350508
Performance & Maintenance
03-28-16 02:49 PM
JBrady
SC- 1st Gen (1992-2000)
11-09-11 07:14 AM
slowdiver
03-27-08 10:02 PM
modifyd
Performance
02-21-06 07:56 PM
reamemiya
06-19-05 12:54 AM
Quick Reply: Supra LSD onto LS400, CONFIRMED!
