All LS400 owners with bad gas mileage READ THIS!
#106
This https://www.clublexus.com/forums/ls4...ange-pics.html (which is located in this thread) in the 5th pic it will show you the ECT, it has 2 wires (green connector). The sensor next to it, with one wire, (black connector) is for the temp gauge on the dash. And then you have the sensor on the bottom of the radiator, which controls the fans. So no they are not the same part.
#107
sensor and sender/sending unit
ok, dumb question here, but i thought that the coolant temperature is what is read on the dash gauge as temp? So, if the coolant temp sensor was showing that cold, the dash gauge would show cold the entire time operating the car? Or, is that temp gauge signaled by the thermostat?
#108
First tank of gas with the new ect... Previously I had a best highway mpg of 17.8. Today with 90% highway driving and speeds between 82 and 95 the majority of the drive I averaged 20.8.
93 ls
93 ls
#109
Does anyone know if this is part of regular servicing from the dealership? Just dont wanna pull everything aparet to find out its alright, although im probably going to test mine first to check unless its visibly in bad condition
#110
#111
#114
ECU = Engine Control Unit
Most initials are all parts. But the list can go on and on for pages and pages. It would take hours to list them all. Some of them do get confusing. If there is a certain one you need to know about you can ask us or google it.
For example something like "AFM in relation to cars" will come up as Air Fuel Meter. Hope that helps.
#115
well, ordered the 2 rear o2 sensors. ill install them when they come in. if this doesnt solve my gas mileage issue, then idk what will. i can smell gas clear as day in the exhaust now. already changed the front 2 like 4-6 weeks ago. new coolant sensor, heads have been off, rebuilt, decarbonized etc... egr system was cleaned out and is working, cats arnt clogged, etc....
speaking of cats. is the single case where the 2 pipes merge right behind the trans a cat or resonator? ive read that it is a cat, and that it is a resonator. which is it? if its a cat, ill just cut the thing out in case it is clogged and replace it with a straight pipe. if its a resonator, no point. it never glows or anything. ive checked. drove the car hard as crap then stop and looked under etc... nothing out of the ordinary.
#116
BahHumBug
#117
mine is shaped more like a muffler, so im guessing it is prolly a resonator. eventually, ill just buy a dual 2.5in exhaust kit from speedway motors and a couple magnaflow mufflers and make a new exhaust from the main cats back and be done with it.
#119
My car used to get decent MPG...
Until I changed the tires from Michelin to Bridgestone since Costco couldn't install an H-rated Primacy MXV4, but they chose to install a Bridgestone Potenza RE960AS instead. The tire is good - except for the rolling resistance. Case in point - a 330 mile roundtrip to Tahoe from my house is usually a 24-25mpg run. Since the Bridgestones were installed, it dropped to 21mpg. Even my normal MPG has dropped from 17-19 to 15!
#120
well, i changed the rear two o2 sensors this morning and the fuel filter. so far so good. exhaust doesnt smell like gas anymore, and i went driving around town. 10 miles or so. romped on it several times. engine light has not come on at all which is another good thing. it was coming on before saying lean even though it wasnt. my last tank of gas was 16.1mpg. i filled up on the way home and reset the trip meter. ill fill up at 300miles and see how it does.
