aftermarket alarms
Old 07-16-08, 01:48 PM
jmannewitz
jmannewitz's Avatar
Default aftermarket alarms
I bought a 94 ls400 and the only key o got was the service key. I want to get the alarm working and I am concerned about getting an aftermarket alarm with the existing Lexus alarm installed. Please help?!
Old 07-22-08, 06:13 PM
ERILUDE
ERILUDE's Avatar
I've been installing professionally for awhile now and I have a 94 LS400. You can integrate an aftermarket quite easily into this car. Hell I even wired in the gas door pop lol. If you need any help in wiring post up!
Old 07-22-08, 08:44 PM
hobojoe
hobojoe's Avatar
super easy on a ls too bypass the alarm just have to do a little searching for the wiring diagrams
Old 07-22-08, 10:03 PM
runumhard
runumhard's Avatar
can you help me out on this...I have a after market and the stock alram hook up...what do i have 2 do to bypass my stock alarm? I have a ucf 10
Old 07-23-08, 01:18 PM
ERILUDE
ERILUDE's Avatar
Well usually aftermarket equipment is not meant to bypass so much as it is integrate if you're using the factory wiring. The lock wire is Green/Yellow and the lock wire is Green, both are negative triggers which means they go to 0v when active or pressed. Now when the right lock wire is tapped the factory alarm and the aftermarket alarm are both active, and when the correct unlock wire is tapped then the factory alarm and the aftermarket alarm are both deactivated. ALWAYS USE A MULTIMETER NO TEST LIGHTS PLEASE!!!
Geezy400
04-30-16 02:29 AM
dumdumgreg
SC- 1st Gen (1992-2000)
04-22-09 12:36 AM
wongerZ
09-03-08 06:19 AM
gandro
ES - 5th Gen (2007-2012)
01-28-08 12:38 AM
Quick Reply: aftermarket alarms
