96 LS, creaking noise...did search
Old 07-13-08, 10:57 PM
LS400_Fan
LS400_Fan's Avatar
Default 96 LS, creaking noise...did search
Ok, i did a bunch of searching but didn't quite find out what i needed. So here's the situation, with the car PARKED if you press down on the front suspension (in this case it's my front passenger) you will hear a pretty loud creaking noise. You can also hear it while driving as the front end compresses/uncompresses.
From what i searched, this sound could be a worn out bushing situation. My car has a little over 110k and i doubt anything has been changed. Now if my upper or lower control arm bushings are bad i did see that i could just replace the bushings, however is there anyway to get OEM bushings only? Or would i have to buy the whole arm for that? Last how much firmer are poly bushings over OEM because i realllly love the cushy ride of my LS. I'm not at all concerned about any type of performance i'd get from poly bushings, i just want the comfy cushy ride.
thanks for any help
Old 07-14-08, 12:20 AM
PureDrifter
BahHumBug
PureDrifter's Avatar
first go check the lower ball joints and the strut bar bushings as they commonly go bad, ball joints normally give more of a "thump" than a "creak"
if it is indeed the control arm bushings then you basically need to go and buy new arms, only poly bushings are available aftermarket (unless you can find a source for australian ADUS bushings here in the US and they make bushings for the 2LS)
poly bushings ride MUCH harder, especially if they're on the control arms.
markdav801
01-17-18 10:56 AM
Ahheck01
Suspension and Brakes
01-12-15 06:27 PM
SuperCoupe400
06-02-07 06:42 AM
Majkmil
03-08-05 03:53 AM
persian451
10-22-03 10:33 PM
Quick Reply: 96 LS, creaking noise...did search
