Another A/C question
Old 07-08-08, 11:31 PM
Tai-Pan
Tai-Pan's Avatar
Default Another A/C question
Last week my LS400 starting making a horrible groaning noise. At the same time the A/C dashboard light started going on an off. I turned off the A/C system and drove home fine. Popped the hood, tried it again, and I got the same noise. A little online research suggests that the light flickering means I need a new compressor.
Ok, but here are the parts I am not sure about:
1) No one ever described that kind of a noise
2) When the car made the noise, it started to pull forward hard, as if the transmission was affected
3) Put a cheapo gauge on the A/C low-side port and is showed the pressure was off-the-dial
4) I tested it after it sat for three days and it seemed to work. However, I only let it run for a minute as I was afraid I might be sending metal shavings into the system.
Do I need a new compressor or am I missing something else?
Also, this is a '94 with 130,000 on the clock. Dropping $1k to have everything replaced makes no sense. Heck, $500 barely makes sense. If I replace the compressor and nothing else, how much longer can I expect the system to function?
Thanks!
jarm
12-22-14 08:57 AM
kikcaffine
04-12-11 09:22 PM
sestepney
RX - 1st Gen (1999-2003)
10-05-07 02:03 PM
lexlyf
Maintenance
07-01-01 11:33 AM
Quick Reply: Another A/C question
