Dreaded driver's door handle has happened
Old 06-24-08, 02:33 PM
peppertree
peppertree's Avatar
Default Dreaded driver's door handle has happened
97 LS400 now with 160K, driver's ouside door handle is splitting past the 50% point. Can I swap it out for the driver's side rear handle? Where buy new handle cheap?
Why the HELL does this have to happen?
thanks for any thoughts
Old 06-24-08, 04:15 PM
PureDrifter
BahHumBug
PureDrifter's Avatar
it just does.
buy a new one from teh dealer, they arent that expensive and iirc for 95+ cars come prepainted.
Old 06-24-08, 07:56 PM
jdmacken
jdmacken's Avatar
Smile Just replaced mine too
No B.S., I replaced mine two days ago. Not too tough to do. About a hour job. My door handle was about $175.00 shipped and already painted.
1990 LS400 ordered from Irontoad.com Good Luck
Old 06-24-08, 08:48 PM
j stuff
j stuff's Avatar
lol mine is cracking too
Old 06-25-08, 04:38 AM
93lexES300
93lexES300's Avatar
Why not glue the handle? Use a plastick backing behind the door handle where you don't se it and glue it with epoxy. Save yourself $175.
Old 06-25-08, 10:30 AM
peppertree
peppertree's Avatar
[QUOTE=jdmacken;3629787]No B.S., I replaced mine two days ago. Not too tough to do. About a hour job. My door handle was about $175.00 shipped and already painted.
1990 LS400 ordered from Irontoad.com Good Luck[/QUOTE
JD, how did you actually do the replacment, do you need to buy a service manual or is there someplace online you refered to for the proceedure?
I am somewhat mechanically competent and would like to do this myself,
but I would have no idea how to take off the inside door, etc etc?
appreciate any and all advice
Old 06-25-08, 11:30 AM
jdmacken
jdmacken's Avatar
Cool How to remove outside door handle.
This is a great resource site for the 1st generation (1990-1994) LS400. Alot of cross over to the Second generation also.
How to remove the inside door panel:
http://www.lexls.com/tutorials/body/fdoorpanel.html
How to remove the outside door handle:
http://www.lexls.com/tutorials/body/fdoorhandle.html
As for the manuals I bought a set off Ebay ( the real factory manuals not an "software set" ) for $75.00
For your car (2nd generation), maybe one of the other members will have a suggestion where to find the factory manual info.
Old 06-25-08, 12:36 PM
peppertree
peppertree's Avatar
JD, thank you, this really helps!
Old 06-26-08, 10:24 PM
Macc
Macc's Avatar
I just epoxied mine with black epoxy. Barely shows and works great...but I'm cheap.
Old 06-27-08, 04:13 PM
richonenz
richonenz's Avatar
The later 95 to 97 handles go straight in the first gen doors , I have just replaced mine with a handle from a 97 Celsior out of Japan , got all 4 for $40.00 , don't know if later than 97 will swap over .
Must research what new ones out of some of the aftermarket shops would cost .
Old 06-29-08, 07:43 AM
LexLS
LexLS's Avatar
I tried to epoxy mine at first but it really didn't help. I suppose it depends on how bad your particular handle is broken/cracked/whatever. It's nice that the handles come in specific colors. Good to know the second gen handles fit first gen too.
YODAONE
08-06-16 01:57 PM
Deuce_B
20
02-19-12 08:06 AM
nll714
01-19-10 04:38 PM
Leisurelar
11-20-09 04:33 PM
DriftGirl
02-27-07 08:53 PM
Quick Reply: Dreaded driver's door handle has happened
