Ls400 audio setup thread (The Mother thread)
#347
I disagree on the original UCF10 stock system quality. My 93 had the Nak and I got the car in 2010. Maybe everything was worn out but I found it dull absolutelyn do depth and sketchy. Wouldn't know a subwoofer existed. I've designed and installed many systems. This one was in bad need of an upgrade. SO I did
#348
#350
Im thinking of placing the JLW7 thats taking up my garage in the back of my Lexus. Mine came with Pioneer System I replaced the foam surround on the factory sub but I want the 12 in the trunk as well. I know the answer might be in this tread but im wondering whats the best way to keep the original stereo and have my 12 powered. I should just buy a head unit but i want to keep it stock looking. I know i could just run a tape/aux to play music but running the rcas to the amp is my question. How and where is everyone running their power and grounds from? I might just spend more time on this tread catching up and find my answers.
#351
I have a '92 with Nak and once I replaced the torn subwoofer the sound was pretty damn good. I have since replaced the head unit and it's better than my 2015 Kia Optima. The problem is the wind noise ruins it.
#352
Hi guys. I had a Pioneer AVH-X8750 installed in my 2000. The headunit is neat, loving the Apple Carplay. But I feel a loss of sound quality from the factory speakers. The install was done without the wiring harness, so some splicing and soldering. The factory amp was bypassed, so I had a spare JBL amp that was lying around fitted instead. Currently there isn't a subwoofer.
I don't know how to explain this 'loss off sound quality'. But when I had the stock stereo, and disconnected the subwoofer (partially blown), the speakers were good enough to listen to music for hours without getting irritated. But now it sounds like there is hardly any low frequencies, making it kinda tinny.
The stock stereo was Premium, non Nak.
#353
Adding a subwoofer will help restore a lot of the bass you are missing.
#354
Yeah. The stock stereo was tuned for the speakers in your doors. The new head unit isn't tuned for your car. What I would do is use the Auto-Tuning feature of your head unit so that it can equalize your speakers properly and go from there. Upgrading your speakers would probably help.
#355
I personally went the aftermarket amp/subwoofer route and got two Rockford Fosgate Punch 12" P1's on a P300X1 amp at 2OHM, pushing about 450W.
#356
wanted to ask. i got a 1st gen 94 ls400
ive changed the head unit and the rear door speakers..
thinking atleast the rear door speakers would improve since i changed the headunit but it still sounds the same ****ty
#358
Secondly, if you're running directly off a head unit, it won't sound great.
Need more details on your setup, "a head unit and new rear door speakers" tells me nothing.
#359
ok but with new speakers wouldnt those new speakers Alone sound new? it still sounds like those speakers are the bust ones i changed out.. are u saying if i were to change the front components the rear ones will all of a sudden get fixed? the problem i have is that the speakers i changed still sound bad even if they were changed. those speakers alone. i know your talking about an all around uppgrade n that the rears make no difference as an over all.of course the fronts is what ill be hearing the most of but why would new speakers still sound like the old busted ones.. for those with first gen ls400s usually need a separate amp for the speakers just to get it to sound not tinny?
#360
does my head unit have a phone option or ?? also thanks for the reply on the other thread.. help is limited on the subject i guess but it was still pretty helpful
