Brake Asssit.
Old 05-14-08, 09:17 AM
bm1139
bm1139's Avatar
Default Brake Asssit.
good day all fellow lex enthusiast, need some advice with my particular problem after changing my brake booster of my 93ls400 (ucf10,right-hand drive)...
old brake booster changed due to hissing sound n deteriorating braking power. found one in the local scrape yard(but with trac n vacum inlet on the left instead of right)that fit the anchoring points.did not disturb the master cylinder during the changing (simply move aside),new gasket for the booster/master cylinder joint n adjusted the booster piston clearance. bled the brakes after fitting the 'new' booster as per manual(with engine on).brake assist was good but the brake dosen't seems to bite/engage; the pedal simply falls all the way to firewall with the engine on but slightly hard but still no bite with engine off.have noticed that the booster piston is pretty loose(it can be pulled out but not out of the booster assembly ofcourse)n the brake fluid is moving up/down everytime i pump the brakes..are these normal??i have changed the master cylinder’s piston about 8months ago..Any advice??do i have to change the master cylinder to a trac type??air in the braking system still??(have notice that brake fluid from the front wheels seems to be flowing out rather slowly as compared to the rears while bleeding it) abs actuatator??
thanks in advance n hope someone could advise .. soon.
Ken167
09-01-18 02:39 PM
AlDavison
11-28-17 04:48 PM
speedkar9
08-19-17 07:52 AM
SorrGwa
Suspension and Brakes
39
05-08-17 04:00 AM
CreativeS
12
11-18-16 06:28 AM
Quick Reply: Brake Asssit.
