Post up Recent pixs of YOUR car (LS400s)
#5582
droop the rear springs some more.. that's the only you'll go lower with the rears. or you can call megan and ask them for another pair of front coilovers (i believe someone here did that), but not sure if they'll grant that since you already drooped the rear springs. i had mine drooping more than 2 inches in order to tuck all tire, was barely tucking rim.
I wonder if the same diameter is used for all the shock bodies. If that is the case technically I could use front shock bodies in the rear... And the fronts have better valving too.
On my EZ's I'm maxed out, but I could still go more. I'm not drooping the spring more than maybe an inch or so right now.
Could something be mixed up on your coils (like the bottom brackets reversed from front to back)? Not sure if that would be possible or if they are different sizes or not. Just a thought.
I would think it would go lower. What size are your wheels, 19's?
Nothing is mixed up or backwards or anything. I thought it would go lower with out sagging the springs. There is so much more threads on the shock body still its weird but owell.
And Yea I'm on 19's I know if I went down to 18's it'll look a lot lower but I'm not wanting to buy another set of wheels at the moment trying to get a ls430 :-)
My cars a first gen not second. I guess I'm also confused?? Are you just saying 2nd gen can get lower then 1st? But all coils claim they're for 95-00 but they fit all generations right? From what I know Megan claims the first gen gets a half inch lower then the other 2.
Correct I have a first gen
#5583
That's what I'm realizing but I might just keep it like this untill next summer. I'm thinking about getting BC extreme drops but ehh I might just mod these I do have friends in high places :-)
i hope you're picking up an 04-06
#5584
UCF10 shock bodies are shorter than UCF20 shock bodies. I'm drooping on both setups. Plenty low. I'm going to be switching my LPs on my UCF20 for some K-Break coilovers so I can have 30kg spring rates. Otherwise, I've had nothing but good experiences with my Megans.
#5588
BahHumBug
This is also the reason 2nd gen coils and shocks (like TeinCS or the Bilsteins) won't work properly on a 1LS. The lack of stroke would cause the coils to prematurely fail. Don't know why megan hasn't changed the labeling, their coils were made/proto'd on a 1LS for use on 1+2LS.
#5589
you have it backwards. The megan coils (and all other coils that claim to fit all LS400s '89-00) were prototyped on a 1st gen '89-94 car. '95-00 cars had a longer stroke from the factory so you can run '89-94 coils on them just fine but they end up lowering the car more than they would a 1st gen.
#5590
nah. the front shock body is shorter than the the rears, which is why the fronts are able to go lower than the rears. the rear shock body was made too long, which is why it maxes out really quick with a bunch of coil thread left. and yes, you can run the fronts on the rears if you wanted to.
Yea I'll be picking up a 05-06 but just waiting for a UL to cross my path.
I just might have to use front shock bodies for the rear so I get more low!
