Which ADUS bushing goes with which arm?
Old 01-19-08, 11:19 PM
en11871
en11871's Avatar
Exclamation Which ADUS bushing goes with which arm?
Hi,
My mechanic showed me the bushing that is almost gone. He lifted the car so I can see. I want to change the bushing to ADUS but don't if it is available or which ADUS bushing will fit. My confusion is that people call these "arms" all by different names. BTW, the bushing is in the rear. I have attached a pic of the rear suspension components for a 96 LS. From the picture, the bushing I need is for part #14. ADUS also has a part number #583 as well. Can someone also tell me which ADUS bushing goes with which "arm" by the diagram part#? Please let me know. Please help. Thanks.
Attached Thumbnails Which ADUS bushing goes with which arm?-lexusls4001996rearsuspension.jpg
Old 01-20-08, 09:14 AM
trukn1
NELOC Mod
trukn1's Avatar
By the looks of it, the part 14 you are referring to is commonly called the strut rod. Officially it is called the the rear trailing arm or rear carrier arm. I am not familiar with the ADUS part numbers so you will have to research a little more on this. You need to find the bushings for the REAR TRAILING ARM or REAR CARRIER ARM bushings. This should help you, even though the tutorial is for a different year LS, it is still the same process to replace.
http://www.lexls.com/tutorials/suspe...abushings.html
In fact if you look at the tutorial, just looked myself. It says that you need ADUS 505 to replace the part.
Old 01-20-08, 12:36 PM
en11871
en11871's Avatar
Post which ADUS bushings go with which arm....
truk,
Thank you so much!!! It is so confusing because everyone calls the respective arms by different names. Take care.
Old 11-21-10, 08:14 PM
VIPjonny
VIPjonny's Avatar
i am also chasing info, can you press the bushes out and replace in the knuckle
lexo101
Suspension and Brakes
07-01-14 04:42 AM
Rey
10-06-11 07:57 PM
stockhatch
14
12-17-10 01:40 PM
JLund
01-07-09 12:11 PM
Ezcompany
Performance & Maintenance
11-15-07 09:20 AM
Quick Reply: Which ADUS bushing goes with which arm?
